6
SHAREit problem
  1. aman_1322 Eclair Jan 17, 2018
    aman_1322, Jan 17, 2018 :
    After updating to oreo there is some problem with hotspot. It doesn't allow SHAREit to create a hotspot when I try to receive any file. Even i tried xender also, it also shows that it is using Bluetooth instead of hotspot because of some restrictions. Anyone else having same problem??
  2. gksujesh Donut Jan 17, 2018
  3. ajshanker Ice Cream Sandwich Jan 17, 2018
  4. Daydreamer8612 Froyo Jan 17, 2018
  5. J.Barathkumar Gingerbread Jan 17, 2018
  6. Xeny Honeycomb Jan 17, 2018
    Xeny, Jan 17, 2018 :
    Creating yourself the hotspot before using Shareit doesn't work ?
  7. Sachin1212 Cupcake Jan 17, 2018
  8. G_aadin_anayodan_AUQk Eclair Jan 17, 2018
  9. aman_1322 Eclair Jan 17, 2018
    Yes i've tried by creating hotspot before receiving but still it does not work. It just ask for the Bluetooth authentication and shows a scan able code to receive file.
  10. aman_1322 Eclair Jan 17, 2018
    Already done idiot
    Santhosh02 likes this.
  11. G_aadin_anayodan_AUQk Eclair Jan 17, 2018
  12. durgraj17 Gingerbread Jan 17, 2018
  13. bad6789 Gingerbread Jan 17, 2018
  14. Roby Mathew Gingerbread Jan 17, 2018
    Roby Mathew, Jan 17, 2018 :
    As a solution just use the scan code method. Scan the QR code with the other phone and it works fine with that.
    kunal.h222 likes this.
  15. Chaitanya_Lakku Gingerbread Jan 17, 2018
    Chaitanya_Lakku, Jan 17, 2018 :
    same here but I have a trick
    1.send any file from ur friend file
    2.click receive in your mobile
    3.you will receive file from your friend
    4.now click send in the same window in which you received file from your friend.
    :) shareit just worked
    if it works
    Removed by mod
  16. Poojith Cupcake Mar 2, 2018
  17. Savio111 Donut Mar 2, 2018
  18. F_Vishnuprasad_Kv_LXwo Eclair Mar 2, 2018
  19. pablofg1978 Spanish POC Assistant Head Moderator Mar 2, 2018
    pablofg1978, Mar 2, 2018 :
    Like farming is not allowed
    GopalB. and idkwhoiam322 like this.
  20. Jugal kalariya Froyo Mar 2, 2018
