3
Shelf - do you use it?
  1. Ludo_Mansio
    Gingerbread Jul 10, 2017
    Ludo_Mansio , Jul 10, 2017 :
    I've come to the OP5 from a phone that took you to Google Now when you swiped right from the home screen. The OP5 has 'shelf' there and compared to Google Now I find it a bit disappointing. So a few questions:
    1. Have you left shelf there when you swipe right, or turned it off?
    2. If you've left it on, have you found something useful to do with it?
    3. Would you prefer Google Now?
  2. princeaj96
    princeaj96 , Jul 10, 2017 :
    2. it's useful ..here we get recent contacts which is useful with whom I'm mostly get connected .. memo's, recent apps & can see the available storage space..it's amazing..
    FullMetalMonkey and sjonnie535 like this.
  3. firoz3321
    Froyo Jul 10, 2017
    firoz3321 , Jul 10, 2017 :
    I used shelf for the first day. Felt useful as i could add all my widgets there. But launcher crashed on me after a reboot so installed the Nova launcher.
    May be there is option to invoke shelf from button combination?
    Will give it a try, but left side panel for me is reserved to Google Now.
  4. zztop007
    Honeycomb Jul 10, 2017
  5. ItsOk236
  6. Pr0metheus2
    Donut Jul 10, 2017
    Pr0metheus2 , Jul 10, 2017 :
    Personally, I don't use it, don't need it. Do not have so many apps installed, so Recent apps is not usable for me. Also Manage center is useless, Recent contacts as well.
  7. matthu.2711
    The Lab - OnePlus 7 Pro Reviewer Jul 10, 2017
  8. Ram Bihade
    Froyo Jul 10, 2017
  9. zal1
    Donut Jul 10, 2017
    zal1 , Jul 10, 2017 :
    I use the Nova launcher too but have enabled Shelf access by double tapping the left button.
    Just assign an action to a button from the Settings menu under the Buttons menu.
    Hope that helps.
  10. Paul.321
    Donut Jul 10, 2017
    Paul.321 , Jul 10, 2017 :
    don't use shelf enough for it to impact me. however I'm sure there is a work around!
  11. zal1
    Donut Jul 10, 2017
    Apologies, my post above was meant as a reply to firoz3321, but I did not quote his text by mistake.
  12. Ludo_Mansio
    I assume you're using a different launcher? I've not found a way of replacing shelf with Google Now... but I'd be interested to know if you can?
  13. Ludo_Mansio
    I might have to switch back to Nova, but I quite like the interface on OP launcher... Nova is great but takes a lot of time to tweak everything (it does for me at least!)
  14. firoz3321
    Froyo Jul 10, 2017
    U can import the OnePlus launcher config to nova. So all shortcuts and widgets will be imported.
    After a reboot the app drawer showed ZERO apps. So had to get back to the trusted Nova.
  15. AbandonedTrolley
    Jelly Bean Jul 10, 2017
    yagna teja and Ludo_Mansio like this.
  16. Rajvez
    Rajvez , Jul 10, 2017 :
    I use it . I have a big calendar widget and a small manage center ....works for me .
  17. olzy
    Cupcake Jul 10, 2017
  18. Yash Bhardwaj
  19. F_Nikhil_Sachan_xpjf
    Donut Jul 10, 2017
  20. Ludo_Mansio
    What do you have on there? Have you added more widgets or just kept the standard recent contacts, recent apps etc?
