Shelf not working via OnePlus 9 Pro
  1. itskunaluknow
    Donut Jan 25, 2022
    itskunaluknow , via OnePlus 9 Pro , Jan 25, 2022 :
    Yesterday updated to latest OS 12 LE2121_11_C.44
    Scrolling down from right side does not open shelf ..it only shows notification panel...this happens most of the time...sometimes it automatically works but other times whatever you do it doesn't show
    PS-Why TF oneplus removed haptic vibrations for volume/brightness slider...it was the best thing ever
  2. Aaron2017
    General Support Expert Award 2021 Jan 25, 2022
    Aaron2017 , Jan 25, 2022 :
    You can try going to settings>apps>app management>tap 3 dots top right corner>show system>shelf and clear it's cache and data.
    You can clear cache (only cache as clearing data for the launcher will delete your layout and settings) for the system launcher too to see if all that helps with this.
    I
    Shailender Sharma likes this.
  3. itskunaluknow
    Donut Jan 25, 2022
  4. Aaron2017
    Oh, okay. There have been other reports from users where they got it working after a factory reset (a hardcore solution that's a pain to do, i know) or where it just starting working properly after some time.
    You can give feedback about the matter here if you want
  5. itskunaluknow
    Donut Jan 25, 2022
  6. Aaron2017
    You're welcome 👍
    Yeah, it's a bit much if that's the only issue you have
