should i upgrade to 7T from 3T??
  1. Sirpranksalot
    Eclair Dec 8, 2019
    Sirpranksalot , via OnePlus 3T , Dec 8, 2019 :
    It would be better to buy 8 then.. Instead of 7t
  2. sutanshu
    Gingerbread Dec 8, 2019
    sutanshu , Dec 8, 2019 :
    Mine 2000 off not working on 7 Pro showing expired or working only on 7T 7T Pro
  3. Infosumit01
    Gingerbread Dec 9, 2019
    Infosumit01 , via OnePlus 3 , Dec 9, 2019 :
    for time being use something else like any budget Xiaomi or Realme Phone.
  4. guanyu210379
    Jelly Bean Dec 11, 2019
    guanyu210379 , Dec 11, 2019 :
    The main problem with 5G is not the phone but the infrastructure. By the time 5G became mainstream, you should be already on your way looking for new smartphone.
    In certain countries, you might be even waiting for another 10-20 years until you get good 5G coverage.
  5. StopItRawr
    Ice Cream Sandwich Dec 11, 2019
    StopItRawr , Dec 11, 2019 :
    Not correct.
    The Snapdragon 765 has an integrated 5G modem.
    The 865 uses an upgraded external one called the X55.
    Praty_28 likes this.
  6. Liehjan
    Lollipop Dec 11, 2019
    Liehjan , Dec 11, 2019 :
    If it still is usable, try to hold on to it another 6 months and go for the op8-series :p
    Sirpranksalot likes this.
  7. Sirpranksalot
    Eclair Dec 11, 2019
  8. Liehjan
    Not really, some sources say April-May 2020
  9. Praty_28
    Praty_28 , Dec 11, 2019 :
    Thanks for correcting me didn't know that :) But even if it is external all the 865 chips will come paired with the modem right? If they made it an external modem i wonder if there will be a 4G only model too for cutting costs in places where 5G won't be coming soon.
  10. Praty_28
    T-Mobile has already launched nationwide 5G in America. So i don't think it's going to take that long to be implemented in other countries as well.
    Also 10-20 years is an overly exaggerated estimate, 5G should start rolling out after mid 2020 in most developing nations. It doesn't have to reach actual 5G speeds even a marginal increase over 4G would be worth it and they can go on eventually adding higher frequency towers over time.
