showing dash charge but not giving speed
  1. The_Rock90 Jelly Bean Jul 29, 2018
    The_Rock90, Jul 29, 2018 :
    while using charger, it shows dash charge in the system but gives speed only upto 1.6amps.... checked with ampere app...
    used different charger and the speed was 3.2amps... what can be the fault? can the charger get repaired or need to replace?
  2. Sun90 Starting Point Expert Jul 29, 2018
    Sun90, Jul 29, 2018 :
    Seems your dash charge unit is the one not working properly.
    You need to replace it since it's not repairable.
  3. hahaha2223 Jelly Bean Jul 29, 2018
    hahaha2223, Jul 29, 2018 :
    Or you're seeing a problem that's not there, but there is a tiny chance that the charger is not working properly
