Display Signal Check Pro not displaying icon on white bg
  1. DerekKY1980
    Cupcake Nov 6, 2018
    DerekKY1980 , Nov 6, 2018 :
    Hi all I was wondering if anyone uses Signal Check Pro on the unlocked version?
    I have the T-Mobile version and I noticed that my icon in the notification bar is always white even when viewing a white bg so it becomes invisible so to speak. I have contacted the makers of the app and they say it's an issue with the OP Launcher and is out of their control.
    It seems to change to black if I use Network Type or Signal Strength (dBm) but if I set it to Signal bars or Network Type and Signal Strength (which is what I usually have it set on) it stays white. Is this a T-Mobile Version issue or is this happening on the unlocked version as well?
    verovoy likes this.
  2. verovoy
    Cupcake Apr 10, 2021
    verovoy , via OnePlus 9 Pro , Apr 10, 2021 :
    Mine's doing the same thing except for now it's not showing anything on the home screen and I've tried both OnePlus and Microsoft launchers
    at least it still works in the drop down notifications
  3. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 12, 2021
    Caoimhín , via OnePlus 6T , Apr 12, 2021 :
    This is the 6T General support thread. Mention it on the 9 Pro thread.
    Also Please send Bug reports and give Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them. Thank you.
    Community App Feedback tool
    You can also contact bughunters@oneplus.com
