Significant battery drain on their OnePlus 7 t series.. via OnePlus 7T Pro
  1. F_Aaron_Thomson_ , via OnePlus 7T Pro , Aug 9, 2020 :
    Guys is anyone facing an issue of significant battery drain... I recently upgraded to 7t pro and am facing battery drainage thanks to the warp charger I don't have a major issue.. But please any suggestions would be greatful.. Thank you
    G.Madhusudhan likes this.
  2. #2
    F_Aaron_Thomson_ likes this.
  3. F_Aaron_Thomson_ , via OnePlus 7T Pro , Aug 9, 2020 :
    I hope they roll out an update to solve this issue
    G1553908988749 and G.Madhusudhan like this.
  4. x_ual
    Cupcake Aug 9, 2020
    x_ual , Aug 9, 2020 :
    I'm on a one plus 6. Exactly the same problem started yesterday. Battery drain like crazy!
  5. L1596821344058
    Cupcake Aug 10, 2020
    Ujjawal_Tandon likes this.
  6. Avadhoot9075
    G1553908988749 likes this.
  7. G1553908988749
    G1553908988749 , Aug 10, 2020 :
    I have the 6t and the exact same thing happened since Saturday. Id understand if it started to gradually get worse but this has never happened before it was fully charged going to bed and 40% waking up!!! I used to get the full day out of the battery and now I'm carrying my charger everywhere! The phone has been overheating a lot too!
  8. Sheppards
    Ice Cream Sandwich Aug 10, 2020
    Sheppards , via OnePlus 7T , Aug 10, 2020 :
    Check your app battery usage, it must be an app you installed.
    You might try enabling battery saver, not sure if that prevents background battery usage.
    Or better yet, set all your apps to optimised or intelligent control, under app settings, advanced and battery optimization
    This should highlight which app is eating your batteries. As I don't have any problems with my battery, I'd say it's not the OS, or any built-in app
    thesign likes this.
  9. Suzanne Stojanovic
    Suzanne Stojanovic , Aug 10, 2020 :
    I have the same problem since yesterday after new oxygen OS update. only 37% this morning after charging all night.
  10. F_Aaron_Thomson_ , via OnePlus 7T Pro , Aug 12, 2020 :
    I had a check on what you said. All the apps are on intelligent mode and secondly I just bought the phone so I haven't installed any additional app yet. I felt an issue just wanted to confirm it.. It started after the recent update.. But thanks for the suggestion [e]263a[/e]️
  11. Sheppards
    Ice Cream Sandwich Aug 12, 2020
    Sheppards , via OnePlus 7T , Aug 12, 2020 :
    No worries. In majority of cases, it's a rogue app.
