9
Significant speed difference between Oxygen stock and Google Now Launcher (OnePlus2)
  1. dertimaushh
    Eclair Nov 2, 2015
  2. joem01
    Gingerbread Nov 2, 2015
    joem01 , Nov 2, 2015 :
    Long time user of Nova here. Couldn't imagine using any other launcher with an AOSP build.
  3. mayankkumar
    Honeycomb Nov 2, 2015
    mayankkumar , Nov 2, 2015 :
    Okay, so yesterday I received my JBL t150 earphones for my #OnePlus2 and the sound quality is incredible. But I am facing one issue. The button on the mic is not functioning properly. Like I inserted it for first time it couldn't play/pause music or take calls. I used it on other device it worked fine then again tried on mine it then started working(not on play music tho) then I sync my accnt on play music and the play pause feature started working fine(even in mx player and es media player). But after i plug it out and then plug in again the button play pause feature doesn't work. Then I try it few time, still doesn't work. Then I restart my device and use it again it worked fine but again I unplugged them and plugged in again and again the play pause feature doesn't work. Sometimes even after restart it doesn't work until after few minutes. So i think it's either compatibility issues or something with the OS? Because earphones work fine in my sis LG device. (korean model) . Guys, please help.
