silent
  1. U1512401271294 Cupcake Dec 7, 2017
  2. ɢноѕтΘпе Starting Point Expert Community Expert Dec 7, 2017
  3. Daan_Eekhofアニメ Jelly Bean Dec 7, 2017
  4. V1525435312539 Donut May 4, 2018
    V1525435312539, May 4, 2018 :
    Only manual toggle switch is given. where is auto settings for keeping the phone silent at night or for configurable time. without this everything else of a wow phone is waste. I forget to switch off the silent toggle everytime. please upgrade ASAP.
  5. ravi603 Froyo May 4, 2018
    ravi603, May 4, 2018 :
    Hi, pl. go to settings -> Advanced -> Scheduled power on / off -> set timings as per your requirement.
  6. Paschfire Jelly Bean May 4, 2018
    Paschfire, May 4, 2018 :
    Oh shutup already, stop repeatedly spamming the OP forums.
    /Reported
    trueheart likes this.
  7. Catalin_Buzescu Jelly Bean May 4, 2018
    Catalin_Buzescu, May 4, 2018 :
    So, by your logic, if you forget to set some stupid ish on your phone, a function should be added promptly into Oxygen OS... Brainstorming at its best!
    I_am_Batman and denxorz like this.
  8. VIVEK264 Cupcake Aug 18, 2018
    VIVEK264, Aug 18, 2018 :
    silent/vibration options in not there in notification bar , its there only in alert slider which is good but people will use frequently then in that case the alert slider will be loose!!
    I think OnePlus should add in your next update!!
    thanks
  9. trueheart Eclair Aug 18, 2018
    trueheart, Aug 18, 2018 :
    Did you guys just buy your phone? Press volume button and adjust your sound volume then if you are worried about the slider.
    No that slider does not become loose. Don't be noob.
  10. trueheart Eclair Aug 18, 2018
    Then get up and switch it off....? Easy no? Or find an app that do that.
  11. VIVEK264 Cupcake Aug 18, 2018
    no it was long back but the thing is, alert slider is getting loose nd the option for silent should be there on the top of the notification Pannel .
    have you ever checked with volume button if yes then you should not give the option, if no then try once you will get to know the major difference between silent nd ringer!!!
    thanks
  12. trueheart Eclair Aug 18, 2018
  13. trueheart Eclair Aug 18, 2018
    The above pic. Forgot to click reply instead of post.
  14. VIVEK264 Cupcake Aug 18, 2018
    one more thing, mind ur language before speaking to public forum, if you will say "noob" nd all then people won't think you r oversmart , they will think you don't have respect for the individual!!
    thanks
  15. VIVEK264 Cupcake Aug 18, 2018
    You don't need silence it doesn't mean that other people don't want!!!!
    think about others , its not your personal forum!!!
  16. trueheart Eclair Aug 18, 2018
    Look at the pic I posted! You can enable silence using the volume button and selecting what you wanted to be silence.
    That's why my volume slider doesn't become loose because I know how to set things.
    And most apps can set notifications sound off.
  17. trueheart Eclair Aug 18, 2018
    I tested. You can't silence ringer with volume button. Only media and alarm. Still need to slider to silence ringer
  18. VIVEK264 Cupcake Aug 18, 2018
    thank god , I am suppose to post here .
  19. trueheart Eclair Aug 18, 2018
    Can we request for the volume button to be able to slide all the way down as well? Lol.... Why did they disable that? Seems counter intuitive (just so they have a reason to have a slider?)
  20. C1541385188376 Cupcake Nov 20, 2018
    C1541385188376, Nov 20, 2018 :
    same here, me too want a geture or toggle to keep phone on silent
