Simcard issues or Device issue ? via OnePlus 7T
  1. Z1603694808821
    Cupcake Aug 1, 2021
    Z1603694808821 , via OnePlus 7T , Aug 1, 2021 :
    While using mobile, suddenly shows no sim card. And no network is detecting. I restarted my mobile, later used sim ejecter and removed the card and reinserted. After that was worked fine. Yesterday suddenly sane thing happened. I replaced the sim from tray 1 to tray 2. Now sim is in 2nd tray. Now works fine.
    I just, I like to know whether it is sim card issue or with device issue ?
  2. Shailender Sharma
    Nougat Aug 1, 2021
    Shailender Sharma , Aug 1, 2021 :
    It might be an ISP issue, if the same issue pops up again try to reset the network adapters in the Settings.
    Aaron2017 and Z1603694808821 like this.
  3. Z1603694808821
    Cupcake Aug 1, 2021
    Dear friend, I tried network settings reset also.
    Not working out
  4. Shailender Sharma
    Nougat Aug 1, 2021
    Are you using an Airtel sim card by chance?
  5. Z1603694808821
    Cupcake Aug 1, 2021
  6. Shailender Sharma
    Nougat Aug 1, 2021
    Aaron2017 likes this.
  7. Z1603694808821
    Cupcake Aug 1, 2021
    Shailender Sharma likes this.
