SIR AFTER ANDROID 11 UPDATE ON MARCH 2021.. I HAVE A HUGE PROBLEM IN GAMING.. via OnePlus 7T
  1. W1576229543264
    Froyo Jul 28, 2021
    W1576229543264 , via OnePlus 7T , Jul 28, 2021 :
    AFTER THE UPDATE TO ANDROID 11 ON MARCH.. SUDDENLY I RECOGNISE THAT MY BULLETS ARE NOT REGISTERING ON ENEMIES WHILE PLAYING PUBG..SO I THOUGHT MAY BE THIS PROBLEM OCCURS DUE TO GAME WAS BAN AT THAT TIME.SO I DONT REPORT ON THIS PROBLEM.. BUT WHEN THE INDIAN PUBG COMES I MEAN BATTLEGROUND MOBILE INDIA I INSTALLED IT IN MY PHONE AND THE PROBLEMS REMAINS SAME.. THE PROBLEM IS BULLETS ARE NOT REGISTERING ON ENEMIES I USED TO FIRE FULL MAGZINE BUT ENEMIES DIDN'T DIE..SO I THOUGHT MAY BE THIS PROBLEM IS OCCURRING DUE TO MY INTERNET..SO I CHANGE MY WIFI OPERATORS BUT STILL PROBLEMS EXIST SO GAIN I CHANGE ANOTHER WIFI OPERATOR'S BUT NOTHING SOLVED..EVEN I PLAYED ON SIM NETWORK LIKE JIO,AIRTEL,VI EVEN IN BSNL..SIR I ALSO HARD RESET(factory reset) MY DEVICE 7 TO 8 TIMES AND UNINSTALL AND REINSTALL THE GAME MANY TIMES BUT STILL NOTHING SOLVED SIR .SO I SEARCHED ON YOUTUBE ON THIS MATTER..I SAW LOTS OF ONEPLUS 7 SERIES USERS HAVING SAME PROBLEMS LIKE ME..EVEN IN ONEPLUS 8T..SIR DO SOMETHING ON THIS..SIR I AM LOOSING MY FAITH ON ONEPLUS SLOWLY SLOWLY..PLSS FIX IT PLSS SIR..🙏🙏
  2. McJader
    Marshmallow Jul 28, 2021
    McJader , Jul 28, 2021 :
    Don't use caps lock, it means you're shouting.
    Remember, this is a user forum, not OnePlus Support.
    Users can't fix it.
  3. Starcommander
    OnePlus Accessory Tester Jul 28, 2021
    Starcommander , Jul 28, 2021 :
    Turn off gyro and check if the problem exists.
    Also is the issue happening under training?
    Shailender Sharma likes this.
  4. W1576229543264
    Froyo Jul 28, 2021
    Bro am a non gyro player..I don't use gyro.. bro I did every possible things to fix these issue.. eveything..but unfortunately I can't fix the problem..help me out pls bro..
  5. Starcommander
    Try to screen record next time the issue occurs.
  6. W1576229543264
    Froyo Jul 28, 2021
    Who told you that I am shouting do u sit beside me or I told you that I am shouting here to share my problems..btw are u blind or what? Literally I am begging for the fix..and you told me that I am shouting out.and if you don't have any solutions regarding my problems then pls stay away from it..
  7. W1576229543264
    Froyo Jul 28, 2021
  8. McJader
    Again, if you use caps lock, it indicates that you're shouting.
    I didn't say you were shouting in real life.
    KluGe and Aaron2017 like this.
