Slow battery charging and draining fast in oneplus 6 via OnePlus 6
  1. stargazer9
    Cupcake Jul 2, 2020
  2. Caomhin
    Lollipop Jul 2, 2020
    Caomhin , via OnePlus 6T , Jul 2, 2020 :
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or Plastic toothpick carefully
    And for the Battery Drain
    Backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, AND then COMPLETE the NEXT steps below to Optimize the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    To Optimize the phone after a Reset, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
