13
slow battery charging (don't hate me, just read once)
  1. kt997 Gingerbread Apr 9, 2017
    kt997, Apr 9, 2017 :
    before you all say that here comes another noob *** guy let me tell you what all have i tried.
    1.changed the cable.
    2.changed the adapter.
    3.changed the plug.
    4.changed the house.
    5.tried with type c adapter.
    6.cleaned the port and blown air into it.(that actually worked 2-3 times).
    now i have no freakin' idea as to what to do with this dumb phone.last time this happened i just changed the cable and it was all ok.but this time it's infuriating.
  2. vinsheri Gingerbread Apr 9, 2017
  3. Noha1990 Cupcake Apr 9, 2017
    Noha1990, Apr 9, 2017 :
    I have the same issue too I think its a bug and it will be resolved with the new update the nougat update
  4. F_Sohail_Fazal_GGuT Cupcake Apr 9, 2017
    aarushrajani likes this.
  5. _DEDSEC_ Jelly Bean Apr 9, 2017
    _DEDSEC_, Apr 9, 2017 :
    c:\\ Did you try clearing the cache partition from recovery.
    c:\\ Should you still face problems, return it to a service center for check up on the USB c port.
  6. kt997 Gingerbread Apr 9, 2017
    if that's the case than i thank the god's good grace.
  7. kt997 Gingerbread Apr 9, 2017
    i even changed my freakin house and you are stuck on cable.
  8. Dunnow The Lab - OnePlus 6 Reviewer Apr 9, 2017
    Dunnow, Apr 9, 2017 :
    pos screenshots of battery usage, do not forget to share the one screen you see when you click the battery graph. I bet it's not slow charge, but fast drain.
  9. kt997 Gingerbread Apr 9, 2017
    i forgot to mention it ..clearing cache was the first thing i did.
    and i don't want to give it to service centre bcz they just make something up for charging me highly.
  10. kt997 Gingerbread Apr 9, 2017
    well i don't think it's a fast drain..cz after the update the battery usage got better.for idle phone atleast.
  11. mschinkelshoek Cupcake Apr 9, 2017
    mschinkelshoek, Apr 9, 2017 :
    It only works with a dash charger and the dash cable. Have a look at your lock screen when you connect the cable. It should say dash charge if the charger and cable are compatible.
  12. kt997 Gingerbread Apr 9, 2017
    ahaha sry dude but it's oneplus 2. it doesn't have dash charge.(OR even Nougat)
    *cries in the corner*
    popaser, sumit.nair and kartike4u like this.
  13. Dunnow The Lab - OnePlus 6 Reviewer Apr 9, 2017
    look at the battery drop, and the awake bar in the screen with the chart, those 2 are correlative to each other.
    you are also charging, by the end of it, but the phone is still awake, therefore, draining fast. Which seems to you as a "slow" charge, but it's instead a rapid discharge.
    you are probably looking at the effects of a wake lock
    @Adam Krisko @david.yang more examples...
  14. kt997 Gingerbread Apr 9, 2017
    umm..i think it shows awake cz i am using it right now.and i have used my phone enough that i know even when i am using it the charging "speed" should not be as low as 730mA..it must be around 1500mA atleast.
  15. Dunnow The Lab - OnePlus 6 Reviewer Apr 9, 2017
    then something is broken, either one of those 2 options.
  16. Hish98 Ice Cream Sandwich Apr 9, 2017
    Hish98, Apr 9, 2017 :
    really? dont you know phone was awake when charger plugged? just check ur battery stats when charging even on screen off lol
  17. kartike4u Ice Cream Sandwich Apr 9, 2017
    kartike4u, Apr 9, 2017 :
    When you are using the charging current is about 1000mah .
    Install "OPO charging current " from play store and open it check the current charging ampere then just turn the screen off without closing that app and wait about 20 seconds and turn on the screen then see the reading in that app , should be more than 1700 or else go to service center as you have tried every other possible method!
  18. Dunnow The Lab - OnePlus 6 Reviewer Apr 9, 2017
    what? Phone is NOT awake while charging it.
  19. kt997 Gingerbread Apr 9, 2017
    hmm.. didn't noticed that. so that is how "ok google" works with screen off while charging..good good.
  20. Hish98 Ice Cream Sandwich Apr 9, 2017
    do you know phone awake when charging?
    just check ur battery stats when charging and see
    that awake time his phone screen on and little bit charging so awake isnt a problem
    i mean the phone have to be awake to charge while power on so its normal
    (sorry for bad english, english isn't my first language anyway )
