4
Slow charging and heating issues in oneplus 8t via OnePlus 8T
  1. O1603480159879
    Donut Apr 20, 2021
    O1603480159879 , via OnePlus 8T , Apr 20, 2021 :
    My OnePlus 8t used to charge 100% in around 40 minutes as stated by the company.
    But now after 6 months, it is taking 50 minutes to getting fully charge even when the phone is switched off.
    And the phone is also heating very quickly while browsing, when hotspot is switched.
    This should not be happening because company claims that they have done some liquid cooling in the battery which prevents phone from heating but phone is still heating.
  2. abidbunny
    Ice Cream Sandwich Apr 20, 2021
    abidbunny , via OnePlus 8T , Apr 20, 2021 :
    I am not facing such issues, try clear all caches and then try.
    Some tips: do not use phone till 0% and never charge phone fully 100% charge your phone when it reaches about 15% and unplugged it after 90.
    Now if you facing heating issue while browsing then I think clear cache will work for you, but as you use hotspot all phone get heated but this phone not heat as much as others. So if cleaning cache not working then visit service center and ask them for software upgrade.
    ehsan1995 likes this.
  3. Supraj_Kumar_K
    Eclair Apr 21, 2021
    Supraj_Kumar_K , via OnePlus 8T , Apr 21, 2021 :
    Am facing the same issue. As mentioned in comment, I used OP6, in that there is no heating issue as this. But this mobile is heating like anything. Sometimes can't hold in hand. Hope in next patches/updates they will resolve this issue.
    ehsan1995, SyamKG and V1618493087182 like this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 22, 2021
    Caomhin , via OnePlus 6T , Apr 22, 2021 :
    Many factors can affect battery and heat, even ambiant air temperatures above 20°c can slow down charging or cause heat issues, as it gets hotter the phone cannot dissipate heat quick enough so may even slow the charging down as a safety measure as well.
    Please check the links below for suggestions and more details on Battery life and Heat issues.
    Battery analysis and battery drain trouble solving by @Swejuggalo
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
    Battery Facts by @TheMystic
    https://forums.oneplus.com/threads/battery-facts.995140/
    Guide to lower Battery Drain.
    Here are some tips to Optimise the use of your phone. This may help with many phone issues.
    By @TheMystic
    https://forums.oneplus.com/threads/updated-2021-setting-up-your-phone-for-best-experience.1415175/
    Ciccius likes this.
  5. Govindarajan_Srinivasan
    Gingerbread May 14, 2021
    ehsan1995, SyamKG and Jenny7777 like this.
  6. Caomhin
    OnePlus 9 Series Expert Community Expert May 14, 2021
    Caomhin , via OnePlus 9 Pro , May 14, 2021 :
    Check the links in the post above yours.
  7. SyamKG
    Ice Cream Sandwich May 16, 2021
  8. Govindarajan_Srinivasan
    Gingerbread May 19, 2021
    Govindarajan_Srinivasan , via OnePlus 8T , May 19, 2021 :
    It's a universal issue on heating while charging of OnePlus 8t. Also, after recent patch update, charging also happens very slowly.
    Hope other 8t users will agree to this complaint.pls clear of this issue in next patch update.
    Abillash@12345 and ehsan1995 like this.
  9. Govindarajan_Srinivasan
    Gingerbread May 26, 2021
