SLOW CHARGING ONEPLUS 2
  1. Dabs14
    Donut Jun 7, 2017
    Dabs14 , Jun 7, 2017 :
    Before updating to 3.5.8 everything was good with this device. It used to take 2.5hours or less to be fully charge from 0-100, but since I updated to 3.5.8 it takes 7-8hours to be fully charged. I did hard reset my device but it's still the same. Please help me with this slow charging. Thanks.
    Uday Ambati likes this.
  2. bingi46
    Honeycomb Jun 7, 2017
    bingi46 , Jun 7, 2017 :
    theres a another thread regarding this issue go thru other threads before making one change ur cable it will stay the same blame oneplus hardware !
  3. sir_adh
    Ice Cream Sandwich Jun 7, 2017
    sir_adh , Jun 7, 2017 :
    1) Did you try charging with a different cable?
    2) Install custom ROM, you won't look back into Oxygen OS
    3) Turn on airplane mode if you want to charge a bit quicker.
    4) Search the thread next time before you make one so that moderators don't have to bother close it ;)
  4. ganeshknr
    ganeshknr , Jun 7, 2017 :
    Check cable, adapter, battery and then chuck phone :D
  5. G_A_ASHOK_tQhm
    Cupcake Jun 7, 2017
  6. Dipak Talsaniya
    Cupcake Jun 7, 2017
  7. Ravi BINAVAT
  8. filogaudenzi
    Cupcake Jun 7, 2017
  9. Uday Ambati
    Cupcake Jun 8, 2017
  10. F_Abhishek_Kumar_IffB
    Donut Jun 10, 2017
  11. Nandish Chandrashekar
    Gingerbread Jun 10, 2017
    Nandish Chandrashekar , Jun 10, 2017 :
    it's the cable problem guys.....
    I use Yu Yureka adapter and letv charging cable...
    if the phone isn't disturbed(not using phone while charging) it takes 1hr 30 minutes to get fully charged.
    if I'm using phone while charging it takes 2 he 30 minutes to get fully charged.
    So, my suggestion is to change the adapter and charging cable (I prefer to use other company cables than OnePlus)
  12. F_Vaibhav_Suman_nPvK
    Cupcake Jun 10, 2017
  13. F_Asvin_Sadhasivuni_bqDt
    Cupcake Jun 18, 2017
  14. Varun_degamwala
    Varun_degamwala , Jun 18, 2017 :
    yes cable is the main issue because i have also been through this once.... i changed the cable and i understood that it's all because of cable
  15. zdnr
    Donut Jun 19, 2017
  16. ravi1979
    Cupcake Jun 19, 2017
    ravi1979 , Jun 19, 2017 :
    hi, faced the same problem. it's the cable fault. buy mivi or alian USB type C from Amazon. phone will charge in 2hrs 10 min.
  17. realfruitloop
    Donut Jun 19, 2017
    realfruitloop , Jun 19, 2017 :
    I'm having a similar problem. Phone is taking 8 hours to fully charge and draining completely in 2 hours. Any ideas on how to fix this?
  18. naikloke
    Cupcake Jun 20, 2017
    naikloke , Jun 20, 2017 :
    i am using le tv adapter and one plus cable
    it takes nwarly 4 hours to full charge
  19. shardulrt
    Donut Jun 21, 2017
    shardulrt , Jun 21, 2017 :
    Use original OnePlus power adaptor and type c cable.
    In case the above are not available, use Anker Power adapter and cable. Also Baseus type C cable also good
  20. G_Shubham_Maurya_aPyS
    Cupcake Jun 21, 2017
    G_Shubham_Maurya_aPyS , Jun 21, 2017 :
    Do you have a torrent client running in the background?? Torrent clients suck the juice just like you queeze a lime.
    Or possibly your battery has malfunctioned.
    Its also possible due to dust accumulation in your charging port as it shots the terminals and drains your battery as the phone is capable of sending power out.
