Slow charging with 65W charger via OnePlus 8T
  1. SyamKG
    Ice Cream Sandwich Apr 1, 2021
    SyamKG , via OnePlus 8T , Apr 1, 2021 :
    So, I bought this 8T model and after the latest update it's charging considerably slower than initially. Earlier it used to charge in around 40min. Now it's taking an hour or so...
    Any workarounds/ Solutions guys??
  2. Liehjan
    Marshmallow Apr 1, 2021
    Liehjan , Apr 1, 2021 :
    Check that there isn't nothing stuck in the phone port that could prevent the cable to be seated correctly.
    S1572899945191 and puccellino like this.
  3. SyamKG
    There's nothing bro. Its brand new 🆕 with not even dust. I saw couple of guys complaining about the same as well.
  4. Liehjan
    If the phone is brand new, there could be some issue with the phone or the wall plug... Do you know anyone with a 8T that could try your charger?
  5. SyamKG
    Happened after the latest update. Earlier I would say it's charging under 45min... I tried charging with the phone switched off..& it was charging quickly. With phone turned on its slow....any solutions..
  6. Liehjan
    Then it has to be something that broke in the last update... Wait for a fix in upcoming update.
  7. SyamKG
    Ok bro. Thanks.
    Liehjan likes this.
  8. ShreyasPatil_
    Jelly Bean Apr 1, 2021
    NaXal likes this.
  9. northbay5566
    northbay5566 , via OnePlus 8T T-Mobile , Apr 1, 2021 :
    But there seems to be a problem with the charging speed when charging after I got the 11.0.8.10 update , I always have to unplug it from the phone and plug it back in for it to actually fast charge seems like that is hanging , but don't know if it the charger or the phone itself
  10. SyamKG
    Try clearing cache from recovery..I did it & there's some improvement now I think
    northbay5566 likes this.
  11. northbay5566
  12. NaXal
    Gingerbread Apr 7, 2021
    NaXal , via OnePlus 8T , Apr 7, 2021 :
    I usually stay between 20-80% charge cycle. Once a week or 10-12 days, I may do a full 100% charge.
    Helps to preserve battery life span.
    Here are my stats.
    I have that charging optimization turned on & ambient temperature is pretty high, 33c !!
    If I turn off that charging optimization option & charge the device in A/C room with ambient temps at around 25c, I see much faster charging time
    But even with optimised slower charging, 24 mins of charge gives me a good 20 hours. I am pretty ok with it :D
    Thanks.
    SyamKG likes this.
  13. MDMujtaba999
    OnePlus Bug Hunter Staff Member Apr 7, 2021
    MDMujtaba999 , Apr 7, 2021 :
    We have responded to your concern via DM, please check for the same and respond with the required information at the earliest.
    Regards,
    Mujtaba
    SyamKG likes this.
  14. vibhorpopli
    Cupcake Apr 18, 2021
    SyamKG likes this.
  15. SyamKG
    Ice Cream Sandwich Apr 18, 2021
    SyamKG , via OnePlus 8T , Apr 18, 2021 :
    In that case it's always better to charge with device turned off. LOL.
  16. TheMystic
    Lollipop Apr 18, 2021
    TheMystic , Apr 18, 2021 :
    I have a better suggestion to improve battery life and lifespan. Uninstall that app (AccuBattery) and stop looking at useless stats.
  17. TheMystic
    I'm on the latest update too, and although I haven't paid too much attention to how long the phone takes to charge, I'm pretty sure it is fast enough (about 45 minutes to charge from 15% to 100%). That's good enough with today's technology.
  18. SyamKG
    Yes. It's respectable. Bu Lt having moved from Realme X2 pro which charged it in 30min..I felt it to be a bit slow. On the brighter side, this doesn't heat up like X2 pro while charging. 😀😀
    TheMystic likes this.
  19. haemtim
    Froyo Apr 18, 2021
    haemtim , via OnePlus 8T , Apr 18, 2021 :
    Have you tried turning off optimised charging in battery settings? It makes your phone charge slower because its better for the battery.
  20. Ak_here
    Cupcake Apr 19, 2021
