slow charging
  1. Prasad2122k Cupcake Jun 7, 2019
    Prasad2122k, Jun 7, 2019 :
    In 1hr my op6t charges upto 88% ,but then it takes nearly 40-45 minutes to fully charge.
  2. drl431 Jelly Bean Jun 7, 2019
    drl431, Jun 7, 2019 :
    My OP6 also reaches about 88% in 1 hour, then finishes 16 - 18 minutes later. The charge rate does decrease significantly at around 90% to protect the battery. Using the phone might increase the time though. I would expect an OP6T to take about 10% longer due to the larger battery.
    Pajamaman18 likes this.
  3. Vikashlb Froyo Jun 13, 2019
    Vikashlb, Jun 13, 2019 :
    it should probably chg 100% within 1hr 20-1hr25mts without using phone while charging
  4. drl431 Jelly Bean Jun 13, 2019
    drl431, Jun 13, 2019 :
    That seems reasonable. Check your cable and the connector on the phone for lint, dust, etc.
