Slow charging via OnePlus 7T
  1. inzmamulhaq
    Cupcake Jun 1, 2021
  2. drmartin
    Moderator Moderator Jun 1, 2021
    drmartin , Jun 1, 2021 :
    Search in the group for slow charging. Often is caused by damaged or old charging cable.
  3. Shailender Sharma
    Nougat Jun 1, 2021
    Shailender Sharma , Jun 1, 2021 :
    Adding to the above post by Mod.
    Clean the USB Port -
    Charging problems may be caused by debris blocking the physical connections in the charging port. Dirt, dust and lint can get between the metal pins of the charging cable and charging port, preventing electricity from flowing. If this is the case, gently swab the connection port with a toothpick to remove any debris. Be careful not to damage the connector pins.
    Aaron2017 and inzmamulhaq like this.
  4. inzmamulhaq
    Cupcake Jun 1, 2021
    inzmamulhaq , via OnePlus 7T , Jun 1, 2021 :
    I don't think that's the problem because the phone is only one month old so maybe it's some app who's causing this problem battery timing is also decreased I noticed
  5. Shailender Sharma
    Nougat Jun 1, 2021
    Try to disable Optimised Charging in the Battery Settings. See, if this works.
    AndroidManiac and Aaron2017 like this.
  6. avinegi102
    Cupcake Jun 13, 2021
    avinegi102 , via OnePlus 7T , Jun 13, 2021 :
    I think this is because of new Android 11 update.
    my phone get 100% in just 40 minutes and 80-82 in 30 minutes now it's taking 2% charge in 1 minute
  7. dastagir.barish
    Cupcake Jun 15, 2021
  8. AndroidManiac
    Honeycomb Jun 16, 2021
  9. AndroidManiac
