slow charging
  1. Sumit lodhi
    Cupcake Jan 3, 2018
  2. Hydra Bob
    Marshmallow Jan 3, 2018
    Hydra Bob , Jan 3, 2018 :
    Well given the amount of information you've provided it could be any one of a multitude of reasons
  3. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jan 3, 2018
    NeVeR_SeTTLe , Jan 3, 2018 :
    I agree with @Hydra Bob
    You need to provide more detailed info. It could be the charger, or it could be the charging port on your device. So many options, so little time...hahaha ;) Just provide more detailed info and me and @Hydra Bob are coming to the rescue and others if they pitch in ;)
    Hydra Bob likes this.
  4. J1513405181224
    Donut Jan 4, 2018
    J1513405181224 , Jan 4, 2018 :
    dash charger isn't charging fast.
    it doesn't show dash charging instead shows charging only.
    I tried with another dash charger same problem exist.
    I tried my charger to another phone it's works completely fine.
    OnePlus 5
    k please help
  5. Hydra Bob
    Marshmallow Jan 4, 2018
    Hydra Bob , Jan 4, 2018 :
    If your charger was able to dash charge another OP phone I would check your charging port and make sure it's free of debris/corrosion and that connection is not loose or visibly broken. If none of that's the case then I think it would most likely be a hardware problem of some sort. The only other longshot I would suggest is I know dash charging is implemented on the kernel level in some part since only certain custom ROMs and kernels support it, so maybe if you tried clean flashing the ROM again you might get lucky(maybe). Other than that I would contact OnePlus support and see what they could do.
    Anything I missed @NeVeR_SeTTLe? I'm coming from an OP2:eek::oops: so dash charging is still kinda new to me:confused:.
    idkwhoiam322 and J1513405181224 like this.
  6. G_naveen_iglesias_dnsd
    Donut Jan 4, 2018
    G_naveen_iglesias_dnsd , Jan 4, 2018 :
    visit op store
    J1513405181224 likes this.
  7. GOWTHAM PRAJWAL
    Froyo Jan 4, 2018
  8. GOWTHAM PRAJWAL
    Froyo Jan 4, 2018
  9. G_Shiny_Lairikyengbam_Df
    Cupcake Jan 4, 2018
    G_Shiny_Lairikyengbam_Df , Jan 4, 2018 :
    same thing is happening with my phone too. what should I do?
  10. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jan 4, 2018
    NeVeR_SeTTLe , Jan 4, 2018 :
    You nailed it head on :) As you said, if he could've charged it on another phone and it showed him dash charge, only on his phone is not showing it, it could be very well the charging port on his phone. The best solution is as what you said, go to Service Center.
    J1513405181224 and Hydra Bob like this.
