Slow Face Unlock OnePlus 6
  1. sandwichk
    Froyo Aug 5, 2018
    sandwichk , Aug 5, 2018 :
    It takes about 0.5 sec to unlock in good light and about a second or more when standing opposite to the light. Is it normal on all OnePlus 6. Its on OOS 5.1.9. My RealMe 1 unlocks in just 0.1 second faster than my fingerprint scanner with a potato cam.
    Any tips to improve it?
    XMANAVX likes this.
  2. hug
    Cupcake Aug 6, 2018
  3. F_Javier_Fernando_Rodrí
    Gingerbread Aug 6, 2018
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Aug 6, 2018
  5. Judgedhook
    Judgedhook , Aug 6, 2018 :
    @SolticeZero absolutely we can complain about it. Especially since the feature functioned faster before. Hardware/Software issues need to be addressed.
  6. CosminOlteanu
    Ice Cream Sandwich Aug 6, 2018
    CosminOlteanu , Aug 6, 2018 :
    It's because you set a 4k picture. Change it with something HD or default from oneplus and check it. It will be faster. I was wondering it's because I'm using Nova. But after some tests.. I found I can use Nova with an HD picture,not 4 k. And if will be instant.
  7. Fredman
    Gingerbread Aug 7, 2018
    Fredman , Aug 7, 2018 :
    Try cleaning the front facing camera with a cotton bud and some glass / screen cleaner. There'll be a lot of oil from your hands and ears built up on it.
    Also worth cleaning the rear camera lenses in the same way (nothing to do with this problem, but you'll get better pictures).
