4
Slow LTE speed on my Oneplus 6
  1. akashhverma
    Froyo Aug 30, 2018
    akashhverma , Aug 30, 2018 :
    I am facing slow speed on my oneplus 6 compare to other devices. I have 5t also and I compared both speed but the speed on my oneplus 6 is very slow compare to 5t.
    Anyone else facing same problem?
    Is this a hardware issue or software?
  2. parikshit123
    Cupcake Aug 30, 2018
  3. Prcko
    KitKat Aug 30, 2018
    A1535617515435 likes this.
  4. J1534842811814
  5. Neeraj@Thakur
  6. F1535612067205
    F1535612067205 , Aug 30, 2018 :
    Yes, same with my Op 6 With both Airtel and specially Jio...Don't know why this happening. My previous Honor was giving good speed than OP 6.
  7. ShineMoses
  8. akashhverma
    Froyo Aug 30, 2018
    Prcko
    use network speed test to compare speed​
    im telling on the based of side by side test only.
  9. Utacka
    Utacka , Aug 30, 2018 :
    I was facing a similiar issue with Tele2, switched to Halebop and the issue is gone. (Sweden)
  10. Prcko
    KitKat Aug 30, 2018
    Prcko , Aug 30, 2018 :
    try to restore network settings
  11. akashhverma
    Froyo Aug 30, 2018
  12. shrinidhi_parla
    Donut Aug 30, 2018
  13. Ali Muhammadx
    Honeycomb Aug 30, 2018
  14. Y1517938924081
    Froyo Aug 30, 2018
    Y1517938924081 , Aug 30, 2018 :
    I had a issue where my 5t had slow network speeds. then I booted into recovery and reinstalled system files and it worked perfect after that.
  15. harshit.b.
    Ice Cream Sandwich Aug 30, 2018
  16. pgrey
    pgrey , Aug 30, 2018 :
    Yep, something is wrong with your provisioning, most likely, or a cached value for your network is corrupt.
    I'm on 5.1.11, and just ran a test (first in awhile), and I'm getting 63/13, and a second test was similar (67/12) enough. Obviously, I'm on a different network (AT&T, US), but we're running the same OS/firmware.
    I haven't (purposely) re-provisioned my phone, or flushed my system cache, since before the 5.1.11 build, just an FYI, in terms of diagnosis.
    I'd be flushing everything I could find, in terms of network, and see if things improve, I suspect you have a bad DNS entry, or similar.
    I'd also be calling my carrier, and asking them to force a re-provision, which sometimes requires talking to a tier-2 tech, but often the tier-1 people know too, it just depends.
    You can see further evidence from the person who switched from "Tele2" above, obviously this forced a FULL re-provision, and then everything was fine.
    There are ways to force a re-provision yourself, but usually it's just easier to ask a tech at your carrier to do it, and it often fixes this issue (since the re-provision will cause all the old values to be flushed, by default, sort of a "super reset" for your LTE network).
    akashhverma likes this.
  17. SVM911
    Honeycomb Aug 31, 2018
    SVM911 , Aug 31, 2018 :
    I think Its software isuue cuz when i was using h2 os beta P Net speed was good but in 5.1.11 it sucks.
  18. G_Viru
    Jelly Bean Aug 31, 2018
  19. tasos4606
    Donut Aug 31, 2018
  20. intrepid013
    Cupcake Aug 31, 2018
    intrepid013 , Aug 31, 2018 :
    I had a similar issue with MetroPCS LTE . The problem was the phone had the Parent Company T-MOBILE APN setting as the default. Once I input the correct APN setting speed had improved.
