Slow motion vedio
  1. nparameah
    Eclair May 24, 2018
    nparameah , May 24, 2018 :
    After selecting the slow motion it is showing very dark display in normal lighting anybody is facing the same? Or its my mobile fault.
    Shivam770 likes this.
  2. Liehjan
    Lollipop May 24, 2018
    Liehjan , May 24, 2018 :
    A quick forum search would have given you the answer.. But luckily I did it for you...
    Looks like you are not alone with that issue
    Shivam770, otto2, iNtEnSePL and 2 others like this.
  3. sumeshbabu
    Cupcake May 24, 2018
  4. Noble10
    Donut May 24, 2018
    Noble10 , May 24, 2018 :
    I also have the same issue with flickering kind of disturbance also. Are they gonna solve it?
  5. indrasingh71
  6. Vivek9036
    Vivek9036 , May 24, 2018 :
    hi all,
    Even I am facing the same issue.
    Slow motion videos are getting flickering..
    Any resolution for that ???
  7. wuyuandaima
    Eclair May 24, 2018
    wuyuandaima , May 24, 2018 :
    yea i ran that slow motion mode,it became darker ,maybe it's not a problem,just like the higher shutter speed in a frame?less light to record?
    otto2 likes this.
  8. U1513149367412
    Honeycomb May 24, 2018
    U1513149367412 , May 24, 2018 :
    yes very dark light with flickering, we have to wait till the next update hopefully they will fix it
  9. iNtEnSePL
    KitKat May 24, 2018
    iNtEnSePL , May 24, 2018 :
    Cupcakes almost solved the mystery ;)
    OK I'll give you two hints...
    1. 480fps is 8x faster than 60Hz and 9,6x faster than 50Hz. What AC power do your lightbulbs use?
    2. at 480fps the phone has roughly 0.0020833333... seconds to record enough light to create a frame. Is is much?
    gubro, otto2, ArmataReloaded and 3 others like this.
  10. U1513149367412
    what are you trying to conclude then with this theory? will it remain the same?
  11. iNtEnSePL
    KitKat May 24, 2018
    I'm trying to give you a hint that will lead to EUREKA! And that will be the end of the thread probably
  12. U1513149367412
    I ain't understanding this sh1t frankly speaking
  13. somuvivekanandan
    Froyo May 24, 2018
    somuvivekanandan , May 24, 2018 :
    flickering will be in artificial lighting..
    iNtEnSePL likes this.
  14. iNtEnSePL
    KitKat May 24, 2018
    OK, try to turn of and on the light in a room, 1 second on, 1 second off. Take pictures every 2 seconds. All your pictures will be either dark, or light. Judging by pictures you will not be able to tell what happens with the light in the room.
    If you change the 2s interval to 0,5s, half of pictures will show light room, and half dark room.
    It's the same when you start recording in high FPS (like 240, 480) in a room lit with AC powered lights.
    The dark pictures come from underexposing, so if exposure time for each frame is short, the picture will be darker at the same ISO, and you can't increase ISO too much as you loose quality.
    otto2 likes this.
  15. W1527081093862
  16. iNtEnSePL
    KitKat May 24, 2018
    bingo, but only AC powered, as DC powered might be stable enough :)
    otto2 likes this.
  17. somuvivekanandan
    Froyo May 24, 2018
    actually understand the mechanism.. the screen will definitely get dark since it takes 480fps.. so the shutter has to be extermely fast.. ISO will be low to reduce noise.. it's happens in all mobile super slow motion tech.. it's not an issue.. and that's why all company opt to advertise their slow motion in good lighting conditions..
    otto2 and iNtEnSePL like this.
  18. rohanzemse
    Eclair May 24, 2018
  19. somuvivekanandan
    Froyo May 24, 2018
    it's nothing to do with ac and DC.. the shutter speed is high as 480fps.. so each frame will be captured in 0.0020833333333 secs .. that's extermely fast man..
  20. iNtEnSePL
    KitKat May 24, 2018
    you are mixing flickering with dark frames. Dark frame comes from short exposure, flickering comes from being able to record the light switching cycle equal to voltage switching (50Hz or 60Hz). Remember your eyes are not perfect, sometimes your camera sees more ;)
    otto2 likes this.
