3
slow motion video recording problem in OnePlus 6
  1. cescafzal
    Donut Oct 5, 2018
    cescafzal , Oct 5, 2018 :
    need an update on this fix ....Come on one plus
    joshdigit likes this.
  2. Aristo_de_melo_99
    Froyo Oct 5, 2018
  3. sskanth999
    Gingerbread Oct 5, 2018
    sskanth999 , Oct 5, 2018 :
    same with me as well. I can see slow motion video taken at 720fps feels like stopping after some frames.
    K1538695292502 and cescafzal like this.
  4. jaapje1988
    Eclair Oct 5, 2018
  5. K1538695292502
    Cupcake Oct 5, 2018
  6. cescafzal
    Donut Oct 5, 2018
    exactly hw do i get it fixed
  7. Clode2018
    Donut Oct 5, 2018
  8. Niklasg85
    Honeycomb Oct 6, 2018
    Niklasg85 , Oct 6, 2018 :
    I don't think OnePlus will ever fix the camera. now when they are releasing the OnePlus 6t! they will focus on that device. they want you to buy that phone! You can follow the hydrogen is beta updates or stable updates because it's copy paste of several improvements on that release for oxygen is.
    Use gcam for picture taking a lot of improvements. I think the camera software of OnePlus is degrading with each update even on 8.1......
    I only use gcam for pictures for now on, and video 4k 60fps in OnePlus camera and that's the only feature I will be using on the stock camera app.
  9. cescafzal
    Donut Oct 6, 2018
    cescafzal , Oct 6, 2018 :
    hw do i dwngrade to oreo
    parthvarasani likes this.
  10. Clode2018
    Donut Oct 6, 2018
  11. Thefatratharish
    Cupcake Oct 6, 2018
    Thefatratharish , Oct 6, 2018 :
    I've got this Same problem with my one plus 6 I don't know what's wrong with the slow motion it's lag and skip the frame
    hope they fix this
  12. Prasanth_Nanjath
    Donut Oct 6, 2018
    Prasanth_Nanjath , Oct 6, 2018 :
    hell ,this is bad ,lot of hiccups 480fps, definitely not the light issue, recorded in broad daylight,it is stuck
  13. Thefatratharish
    Cupcake Oct 6, 2018
    yeah little bit lag and frame drops and frame skip at resoultion 720p @480fps what's wrong with the slow motion I think this is happening because of Android pie after upgrade my phone to Android pie I saw this problem in my phone so do you get this Same issues with your phone ? and what's you Android version??
  14. Prasanth_Nanjath
    Donut Oct 6, 2018
    pie,same,only after the update it is like this
  15. Clode2018
    Donut Oct 6, 2018
    Clode2018 , Oct 6, 2018 :
    This is a video in Italian but below there are links to download oreo 8.1 is easy
  16. Clode2018
    Donut Oct 6, 2018
    now 8.1
  17. Thefatratharish
    Cupcake Oct 6, 2018
    before update do you check your slow motion feature does it works fine for you?? at 720p @480fps does work well or you have the same problem on Android orieo
    ?? cause we're using Android pie beta version on our one plus 6 and I think official Android pie Will take some time to come and hope the next update have sulome improvements .
  18. Prasanth_Nanjath
    Donut Oct 6, 2018
    it was good earlier,I'm sure ,I have taken multiple recordings
    #38
    cescafzal likes this.
  19. Clode2018
    Donut Oct 6, 2018
    #39
  20. Prasanth_Nanjath
    Donut Oct 6, 2018
    #40
