4
Slow response of display brightness while adjusting manually in oneplus 9 pro via OnePlus 9 Pro co-developed with Hasselblad
  1. #1
  2. #2
    Akshansh_Jaiswal likes this.
  3. #3
  4. McLarenMania
    Honeycomb Apr 18, 2021
  5. #5
  6. McLarenMania
    McLarenMania , via OnePlus 7T Pro 5G , Apr 18, 2021 :
    If this is not one off and replicable each time you use the slider, worth raising with CS for a replacement if still within the return period.
  7. #7
  8. Akshansh_Jaiswal , via OnePlus 9 Pro co-developed with Hasselblad , Apr 18, 2021 :
    It looks like a software issue because auto brightness works well (very responsive) but manual slider responsiveness too slow
  9. McLarenMania
    Please submit feedback and bug. Hope it gets resolved quickly. If not worth swapping just in case it gets worse. I am an OCD 😃 when it comes to such niggles
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 18, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 18, 2021 :
    Tried this too. No so sure it's an issue though. It seems to use incremental steps to make a softer transition. Could be by design instead of just jumping directly. It may be unnecessary slow though.
    Thariq.mcknight likes this.
  11. MDMujtaba999
    Jelly Bean Staff Member Apr 18, 2021
    MDMujtaba999 , Apr 18, 2021 :
    We would like to check this further and have got in touch with you via personal conversation for more details.
    Please requesting you to respond to us at the earliest.
    Regards,
    Mujtaba
  12. Akshansh_Jaiswal , via OnePlus 9 Pro co-developed with Hasselblad , Apr 18, 2021 :
    It makes makes me feel that device is too slow in responding brightness level that i need. In manual adjustment what i believe it needs to be be responsive (no delay).In this case it's a considerable delay.(for eg just see delay when when setting brightness from lowest to highest level)
  13. MDMujtaba999
    We have responded to your concern via DM, please check for the same and respond with the required information at the earliest.
    Regards,
    Mujtaba
  14. RohanRawat25
    Cupcake Apr 19, 2021
    RohanRawat25 , via OnePlus 9 Pro , Apr 19, 2021 :
    Same issue with my device, but doesn't care about the slow transition, I'm more concerned with it struggling at low brightness, seems like it's adjusting the brightness by itself even with auto brightness turned off
  15. Rony56784321
    Froyo Apr 20, 2021
    Rony56784321 , via OnePlus 9 Pro , Apr 20, 2021 :
    The brightness thing is very sketchy out here in OnePlus 9 Pro..
    I am using the Stelar Black, 12GB RAM Variant.
    In dark mode, even if auto brightness is off, then also brightness dims down suddenly, while switching between apps. Though the brightness level on the bar stays the same.
    They need to fix a loads of things...
  16. manpreet3260
    Cupcake Apr 21, 2021
  17. squelch91
    Cupcake Jul 20, 2021
    squelch91 , Jul 20, 2021 :
    I have the same issue with my OnePlus 9 pro.... Adaptive brightness is ok it doesn't happen but I prefer to have the brightness on manual ... Doesn't happen everytime but quite often when I click the phone on in is very dim and works it way up slowly to the set brightness ..... I raised this with OnePlus and they sent me a huge list of instructions to get data reports and more it was all very confusing and I do feel as though I have been fobbed off with this and that's all they are going to do .... They should be investigating this themselves and patch with update ! Not good
    F1633839637116 likes this.
  18. #18
  19. #19
  20. korteur
    Cupcake Oct 5, 2021
    korteur , Oct 5, 2021 :
    Same issue since the OxygenOS 11.1.1.1 update. Oneplus 6. OxygenOS 10 worked well.
