Slow scrolling speed one plus 8t
  1. Action_Pretty
    Honeycomb Dec 15, 2020
    Action_Pretty , via OnePlus 8T , Dec 15, 2020 :
    Same problem, coming from op7 pro where everything works perfect to this mess of a OS. Oneplus should be ashamed! Refresh rate doesn't matter, the scrolling just sucks. Oneplus have no consistency, you get use to something, next update or device they take it away...
    Chris_Punj_6803 likes this.
  2. #22
  3. Ganymede25
    Gingerbread Dec 15, 2020
  4. Chris_Punj_6803
    Eclair Dec 16, 2020
    Chris_Punj_6803 , via OnePlus 8T , Dec 16, 2020 :
    For all who have one plus 8t i am sure we r using 120hz. I am using 120hz and why wont i.
    However it doesn't matter. The scrolling speed is STILL POOR as compared to previous models. I have op6 and wife has op7 and they both offer much better scrolling speed compared to 8T.
    How can we raise this to Oneplus so that this can be fixed????
    Else i am going back to my op6.
    Egor Bryzgalov likes this.
  5. Chris_Punj_6803
    Eclair Dec 29, 2020
    Chris_Punj_6803 , via OnePlus 8T , Dec 29, 2020 :
    I think its the worst purchase i have made for my one plus phones. It is certainly not upto the mark.
    Issues i am facing -
    1) Slow scrolling speed and pls i have it setup at 120HZ. Still scrolling speed is slow. My old OP6 gives better speed.
    2) Face Unlock doesn't work in the dark room even with full brightness. Again, my old OP6 does open up with least brightness.
    I guess this is the worst experience I've had with oneplus phones thus far. I am packing this device and using my OP6 which is still much much much better than the new OP6. I have used oneplus 1, 3, 6, also have 7T and now 8T.
    If oneplus makes any changes or resolve issues in next software update then will start using it again. Till then oneplus 8T is boxed again.
  6. eastbay
    KitKat Dec 29, 2020
  7. thorvex
    Cupcake Jan 6, 2021
    thorvex , via OnePlus 8T , Jan 6, 2021 :
    I do have the same problems on my 8T.
    Scrolling is very inconsistent. Most of the time is very slow, especially when compared with a OnePlus 7Pro (my girlfriend's phone). said:
    In most apps, even stock ones, seems to drag too much.
    eastbay likes this.
  8. #29
  9. Egor Bryzgalov
    Cupcake Mar 5, 2021
  10. BEsco83
    Cupcake Mar 5, 2021
  11. eastbay
    KitKat Mar 5, 2021
    eastbay , via OnePlus 8T T-Mobile , Mar 5, 2021 :
    Sir you've never encounters a stuttering a hiccup. Just down right sluggish on certain page's not supported by oneplus. I've got mine on 120. It happen on FB. Sometimes on a news feed Page I just want it smooth on everypage!! This is my 4th OnePlus. So I feel it's a fix. Thank God it's not major like some things I read!! ✌🏻 Thanks 👍🏻
    MRTLima likes this.
  12. Manos_Gr
    Cupcake Apr 10, 2021
    Manos_Gr , Apr 10, 2021 :
    I had the same problem while scrolling in different apps.
    What helped was the following:
    1. Enable Developer Options Enable Developer Options & USB Debugging on OnePlus 8T [Guide] (thecustomdroid.com)
    2. Enter Developer Options
    3. Disable HW overlays (always use GPU for screen compositing)
    In the Developer Options i also reduced the speed of
    a. Window Animation Scale to 0.5x
    b. Transition Animation Scale to 0.5x
    c. Animator Duration Scale to 0.5x
    The refreshing rate is at 120Hz.
    Restart and try with your Apps.
    The scrolling should be smooth as expected.
    I would be glad to read any Feedback as i was very disappointed with Oneplus.
    P.S. This video came in handy:
