Slw speed in use via OnePlus 8T
  1. Ankis007
    Cupcake Oct 20, 2021
    Ankis007 , via OnePlus 8T , Oct 20, 2021 :
    Very slow speed in use and every time I need to restart my phone and it looks like the refresh rate is very low even though I am using 120
  2. psygarden
    OnePlus TV Product Ninja 2021 Oct 20, 2021
  3. harshit.b.
    Jelly Bean Oct 20, 2021
    harshit.b. , via OnePlus 6 , Oct 20, 2021 :
    If you're saying your phone in general feels slower then you might want to try factory resetting your phone or you can also try clearing the system cache from the recovery mode and see if that helps.
  4. BetaBot
    Jelly Bean Oct 21, 2021
  5. puccellino
    Lollipop Oct 24, 2021
    puccellino , Oct 24, 2021 :
    Yep, the phones do slow down with use, they sort of get clogged up with useless stuff. Try running your phone in safe mode, if it's a bit faster, you will know it's apps and app debris that's causing the issue.
    The best way to tackle this, is try a bit of basic clearing up, remove cache files, on Google/search engine clear your history and cookies regularly, close apps that run in the background, and remove apps you don't use.
