Small Dash Cable
  1. G_Ranjan_Prasad_ICdX
    Eclair Jun 17, 2018
    G_Ranjan_Prasad_ICdX , Jun 17, 2018 :
    Is there a way to get short dash cables for Power Banks or any short cables that support dash charging....?
    I guess the wireless bullets have short dash cable. Is there any way to buy that cable itself?
  2. appupd
    Donut Jun 18, 2018
    appupd , Jun 18, 2018 :
    If you are using a power bank, then what is the purpose of dash cable?
    Normal power banks wont support dash charging anyway.
  3. Mjo
    Marshmallow Jun 18, 2018
    Mjo , Jun 18, 2018 :
    you could try buying the oneplus fast car charger bundle. I think the cable is much shorter in that bundle
    G_Ranjan_Prasad_ICdX likes this.
  4. G_Ranjan_Prasad_ICdX
    Eclair Jun 19, 2018
    G_Ranjan_Prasad_ICdX , Jun 19, 2018 :
    But the dash cable will be the fastest charging cable amoung all the cables. So it will be better
  5. tfae
    Ice Cream Sandwich Aug 23, 2018
    tfae , Aug 23, 2018 :
    There ARE power banks compatible with DASH charging. I have a Mopoer but there is an OPPO VOOC power bank, which is compatible with DASH.
    A small DASH cable would be really great to use with it.
    The cable size on the car DASH Charger is 1 meter. The same that comes with the smartphone.
  6. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Aug 23, 2018
    KeepTransisting , Aug 23, 2018 :
    This is false. A cable is only as good as the source feeding it. If your power bank does not support Dash Charging (which I can 99% guarantee it doesn't), you will see zero charging speed increase
