Smart content detection of camera is not working
  1. Pranjalchamp
    Cupcake Jun 7, 2020
    Pranjalchamp , Jun 7, 2020 :
    Help me, my camera's smart content detection is not working, i.e. not showing in the screen.
  2. rhyd1am
    Jelly Bean Jun 7, 2020
    Caomhin and Artemus. like this.
  3. Pranjalchamp
    Cupcake Jun 7, 2020
    yes, it is enabled and then also not showing in camera screen
  4. rhyd1am
    Cazladz, Artemus. and Pranjalchamp like this.
  5. Pranjalchamp
    Cupcake Jun 8, 2020
    Pranjalchamp , Jun 8, 2020 :
    thank you. it finally worked🤗
    but can I get the previous version back of getting it on camera screen
    rhyd1am likes this.
  6. rhyd1am
    Jelly Bean Jun 8, 2020
    rhyd1am , via OnePlus Community App , Jun 8, 2020 :
    You would have to download an older version of the camera app from somewhere like APK mirror, but that would be a little bit of trial and error to find the one you're after. Would also have to check that it is a version meant for 6 series devices, since not all versions are designed for 6 series.
    Caomhin, Artemus. and Pranjalchamp like this.
  7. P1589124779290
    Cupcake Jul 28, 2020
    P1589124779290 , Jul 28, 2020 :
    Hello,
    I am using OnePlus 8 and my smart detection feature is not working in camera app latest version. The option is already enabled in the settings and even after long pressing on view finder it doesn't show anything.
    Can anyone help ?
  8. Caomhin
    Lollipop Jul 28, 2020
    Caomhin , via OnePlus 6T , Jul 28, 2020 :
    Clear your OnePlus Camera App info Cache and App info Storage.
    Then open Camera settings and re-enable Smart Content Detection. Go back to the Camera and long press the viewfinder on the screen.
    See if that helps.
  9. P1589124779290
    Cupcake Jul 29, 2020
    P1589124779290 , Jul 29, 2020 :
    Hey
    I tried this but it didn't help. Facing same issue still. Long press is giving no response even after smart detection option is enabled.
  10. Caomhin
    Lollipop Jul 29, 2020
    Caomhin , via OnePlus 6T , Jul 29, 2020 :
    Reinstall the latest Stock OnePlus Camera version.
    First uninstall the current OnePlus Camera. Go to Camera App info, click on the 3 dot menu and uninstall updates.
    Then install most recent stock camera for the 6 series phone.
    https://www.apkmirror.com/apk/onepl.../oneplus-camera-3-8-114-android-apk-download/
    Also Download and install OnePlus Camera Service
    https://www.apkmirror.com/apk/onepl...service-2-2-13-android-apk-download/download/
    Then go to Camera Settings and make sure Smart Content Detection is enabled.
    See if that helps.
