Smart Display missing in Oxygen OS 10.0.1 OP7
  1. indranilchatterjee.mktg
    Cupcake Oct 17, 2019
    indranilchatterjee.mktg , Oct 17, 2019 :
    Hi
    have just updated to Oxygen Os 10.0.1 but the smart Display option is not there under ambient display option as stated in the changelog
  2. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 17, 2019 :
    Bro, the name smart display, has been changed to contextual info, in 10.0 it was called as smart display but after in 10.0.1 it has been renamed as contextual info.
    Answer for your question has been already posted in many thread so, it would be really great if you get in touch with search engine before you create another redundant thread.
  3. Mohakur
    Cupcake Oct 18, 2019
    Mohakur , via OnePlus 7 , Oct 18, 2019 :
    bro after the recent update facing network issue like CA not working properly only working with band 40 to 40
    kindly check
    no problem with previous version it will support all the available band's between 3,5 and 40
    so i roll back to previous version
  4. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    Bro, i have checked and i have no such issues everything works fine.
  5. Mohakur
    bro see this on android 10 getting 2ca between 40 and 40
    on pie it will work with all the combination see the attachment screen shot belongs to Android 9. and photo copy belongs to Android 10
  6. #6
  7. Mohakur
    no apps bro
    just get it from dialler menu on phone info will get this information
    if your jio user install netvelocity it will show on which band your connected
    then you can check 3ca or 2ca from dialler menu
  8. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    I checked the band shows me is 2300.
  9. Mohakur
    hope your using jio
    2300 mhz means band 40
    so now open the dialler dial *#*#4636#*#* then select phone info now you will see the lte configuration channel
    ther you can see 2ca or 3ca if possible post the screen shot
  10. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    Bro i dont find anything like 2 or 3 ca, but here is the screen shot.
    Could you tell me where it is?
  11. Mohakur
    bro on your attachment no CA working it's just 4g lte may be with band 3 or 5
    see my screen shot you will find 3 servings means 3ca
  12. Mohakur
    s bro CA not working on your handset raise the issue in feedback and post the community
    developers will look into this
    if you need proper ca then you have to downgrade to previous version then you can feel the difference
  13. #13
  14. Mohakur
    bro see the screen shot primary service on 10000mhz
    and secondary on 20000mhz
    and another one on 5000mhz
    that means 3ca in india maximum we 3ca from jio and airtel on different band's
    hope you got it now!
  15. #15
  16. Mohakur
    bro after the latest update CA not working properly on band 3and 5
    it's working with band 40 to 40 it means intra band
    previous version fine with inter band ca with all the combination
  17. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    k bro, will this make any difference in data speed?
  18. Mohakur
    200% bro u won't feel sufficient Speed on data downloading through mobile data on this ca intra combination
    inter band ca very powerful it will connect all the available band's so we feel the difference
  19. Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    yeah bro, you are right but when i tested with net velocity i got fast data speed but in real time the data speed in sim 1 is very slow but in sim 2 it it has great data speed why does it happens in only sim 1?
    here is the screen shot of net velocity.
  20. Mohakur
    bro you have good rsrq and sinr on band 40 so getting this speed if your in low signal area then you feel much difference
    it's a software bug bro
    so only yesterday i updated and noted CA not working and display brightness issue
    so i downgrade to previous version
