Smart Lock Blank Screen
Thread Status:
Not open for further replies.
  1. AEssaian
    Cupcake Sep 2, 2017
    AEssaian , Sep 2, 2017 :
    So I used smart lock for a while and loved it. I use a pin and have trusted agents on for smart lock. Recently I noticed that it doesn't work. When I click on the smart lock option, a blank screen pops up and I have no choice to click. Can anyone help?
    zsunberg likes this.
  2. G_Joe_Smart_Ltmx
    Honeycomb Sep 2, 2017
    G_Joe_Smart_Ltmx , Sep 2, 2017 :
    I think that might be a bug with the latest OOS update because all of my Smart Lock options are gone as well and I now just get a blank screen.
    Since I manually flashed the update and cleared the cache before booting up clearing the system cache is unlikely to do you any good.
    There is a thread on XDA where the devs post the latest OOS builds and people post bugs that they notice. I wasn't using Smart Lock so I didn't realize it was gone. You can post the bug on the XDA Thread and see if anyone else has reported the same issue. Also sometimes when there is a bug OOS devs or other users figure out a workaround and post it.
  3. rafael.akio
    Cupcake Sep 5, 2017
    rafael.akio , Sep 5, 2017 :
    I'm facing the same issue. Definitely it starts from the latest OOS update.
    In my case it still working facing detection but I can't change to use voice. Just stuck in the blank screen.
    I did the wipe cache procedures but it didn't work for me.
    I found the solution...
    To solve this issue follow this steps:
    1) Go to Security & Fingerprint
    2) Trust agents
    3) Disable Smart Lock
    4) Reboot your device
    5) Enable Smart Lock
    It should solve the issue, it works for me.
  4. Datoneplus
    Froyo Sep 9, 2017
    Datoneplus , Sep 9, 2017 :
    It didn't work for me
  5. Suwaid Akbar
    Cupcake Oct 8, 2017
    Suwaid Akbar , Oct 8, 2017 :
    This worked for me....thanks...
    Máté Ócsai likes this.
  6. G_Anil_P_mTMK
    Cupcake Oct 17, 2017
  7. wileyc
    Jelly Bean Oct 17, 2017
    otto2 likes this.
  8. Q1513951984421
    Cupcake Dec 22, 2017
    Q1513951984421 , Dec 22, 2017 :
    I had the same issue on my note 8. After I installed company porthole to receive company emails my smart lock page shows up empty. I uninstalled Microsoft Porthole which allows the company access to my phone so they can delete all emails, files ,and photos. I can just check my emails at work I didn't like them having that cannot control over my phone anyway.
  9. psideburns
    Froyo Jan 27, 2018
    psideburns , Jan 27, 2018 :
    Yes this worked for me as well, thank you very much for the great tip!
  10. Timmy01
    Cupcake Feb 23, 2018
    Timmy01 , Feb 23, 2018 :
    And for me too, thought installing many launchers was the reasons why all these things happening, thanks a lot!!!!
  11. JonDeutsch
    Eclair Jun 21, 2018
    JonDeutsch , Jun 21, 2018 :
    Yes, this work-around works, but it's incredibly annoying to have to reboot twice for every time you need to reboot once. :(
  12. ksahnan
    Cupcake Aug 11, 2018
    ksahnan , Aug 11, 2018 :
    This worked for me mate, thank you!
  13. Funk Wizard
    Lollipop Moderator Nov 28, 2018
