34
smart lock doesn't show any options
  1. kimmiene
    Eclair Dec 22, 2017
  2. pablofg1978
    Nougat Head Moderator Dec 22, 2017
    pablofg1978 , Dec 22, 2017 :
    Thread merged
    Jaygandhi285 likes this.
  3. KSHITIJ1239
    Cupcake Dec 22, 2017
  4. O1509764590747
    Cupcake Dec 23, 2017
  5. Hizkia JK
    Donut Dec 26, 2017
    Hizkia JK , Dec 26, 2017 :
    so i got my OP 5 for abt a month now and i usually use the smartlock for face unlock so tht i dont always have to type in my password/ use the fingerprint. but suddenly after i downloaded an apk from the internet,
    the smartlock doesnt function anymore
  6. Whrebe
    Gingerbread Dec 26, 2017
  7. Hizkia JK
    Donut Dec 26, 2017
  8. pablofg1978
    Nougat Head Moderator Dec 26, 2017
    pablofg1978 , Dec 26, 2017 :
    Thread merged
  9. Hizkia JK
    Donut Dec 26, 2017
    thank youuuu ^-^... it worked for me
  10. Whrebe
    Whrebe , Dec 26, 2017 :
    Use the forum search option, there are over 500 other users who also have this problem and all open a new topic before searching if the solution no longer exists in the forum...
  11. Hizkia JK
    Donut Dec 26, 2017
    ok ok. thanks dude [e]1f601[/e][e]1f601[/e]
  12. 3p1phany
    Donut Dec 26, 2017
    3p1phany , Dec 26, 2017 :
    For what it's worth, this problem is fixed in the Oreo update. I've rebooted a number of times and smart lock works fine, options don't vanish.
  13. yung40oz84
    Froyo Dec 28, 2017
    yung40oz84 , Dec 28, 2017 :
    All the fixes for this. Disabling trust agent, wiping cache, etc. is only temporary. I have been testing this extensively for weeks, and then more thoroughly for several days now. I tried every possible fix and solution to get smart Lock to stay active and yet it always stopped working and when going into the settings I would see everything is blank white screen.
    I then decrypted my device and quickly found that, oh my goodness, smart Lock is staying active. I did everything to reproduce the issue, the same things I did encrypted and it never disappeared.
    I encrypted and decrypted 5 separate times, going back and forth with the exact same result over and over and over again. Encrypted=eventually smart Lock disappeared. Decrypted=Never disappeared.
    Now I'm not a Dev by a long shot but I have been testing kernels, ROMs, and app extensively for the past 5 years or so with some of the best devs put there.
    My assumption is that the FBE(File Based Encryption) is somehow screwing smart Lock up. I've never had an issue with smart Lock on a FDE(Full Disk Encrypted) device through all my years.
    No matter what the cause, if you actually want smart lock to stay and use it consistently, decrypting and staying decrypted is the only option I found that keeps it active and working and I messed with this for a couple weeks all together tested my theory over and over. I haven't had smart lock go out on me one single time since decrypted.
  14. Q1511525028932
    Cupcake Dec 29, 2017
  15. pablofg1978
    Nougat Head Moderator Dec 29, 2017
  16. 9620070551
    Cupcake Dec 30, 2017
    9620070551 , Dec 30, 2017 :
    so true this happens. after the update the battery life finger print or the smart lock. nothing works
  17. Nikesh_venkata
  18. pablofg1978
    Nougat Head Moderator Dec 30, 2017
  19. 9620070551
    so true this happens. after the update the battery life finger print or the smart lock. nothing works.
  20. yugesh kumar
    Eclair Dec 31, 2017
    yugesh kumar , Dec 31, 2017 :
    I have been using smart lock features on my op5 suddenly now the smart lock is not working when I tried to enter in the setting page of the same nothing shows there ... please resolve it
