Smart WiFi issue poll
Have you had problems with WiFi auto-connect since updating your phone?
  1. Yes, but its intermittent
    1 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. jontalk
    Cupcake Mar 25, 2020 at 5:49 PM
    jontalk , Mar 25, 2020 at 5:49 PM :
    While I love my 5T, when 9.0.8 was released, I began having intermittent problems with the auto-connect feature (Smart WiFi). With subsequent updates, it continued and having installed the latest 9.0.11 it won't work at all. Where third party apps are concerned most are banking, Norton clean, WiFi analyzer, Swiftkey, and a few others none of which run in the background. No social media, gaming or utilities. The feature is part of the Android kernel rather than unique to OP. I'm curious if anyone else has experienced this and if so, if you've been able to correct it. I've done both hard and soft resets which take hours to restore the phone back to normal. It's a MINOR issue, but annoying since it worked perfectly prior to 9.0.8. Thanks
