sms
  1. vijay kor
    Cupcake Oct 10, 2018
    vijay kor , Oct 10, 2018 :
    message app oprn but when i select contact for sms that automatically app close and show's disply message keep stoping
    what is issue pls tell
  2. hotsauce
    Lollipop Oct 10, 2018
    hotsauce , Oct 10, 2018 :
    try to clear cache and restart device
  3. vijay kor
    i do it already sir
  4. hotsauce
    OK, next step is to do a factory reset of the phone. If that still doesn't fix the issue. Then you need to call customer support to get a new phone.
  5. ngydat
    ngydat , Oct 10, 2018 :
    Well it depends. When did @vijay kor start having this issue ? If this was there only since he's on Pie, it's not a hardware issue.
  6. hotsauce
    Actually it doesn't matter. If after p update SMS stop working and factory reset doesn't resolve. That is now a oneplus issue and phone is eligible for RMA imo. Sms is a must have function.
  7. ngydat
    Yeah, fair enough. In my opinion, One Plus shouldn't have developed this sms app in the first place.
    deangilvin likes this.
  8. hotsauce
    Yes it is horrible. I'm using Textra, this was actually the first phone that I had to download a new SMS app
    Artemus likes this.
  9. Mist53
    Cupcake Oct 11, 2018
    Mist53 , Oct 11, 2018 :
    Its because of enabling parallel apps. If i enable parallel apps then i stop receiving sms
  10. ngydat
    Lollipop Oct 11, 2018
    ngydat , Oct 11, 2018 :
    @vijay kor's issue is the messaging app that force closes. Not the same issue as yours (not being able to receive texts)
  11. vijay kor
    vijay kor , Oct 11, 2018 :
    my issue is that the
    when i open sms app after that select contact icon for send sms that time the app will automatically closed but i go directly in contact list select contact and after open contact then select sms icon that time sms will send
