Snapchat battery drain (please help)
  1. G_Rajun_Doal_Ieis
    Honeycomb May 20, 2017
    G_Rajun_Doal_Ieis , May 20, 2017 :
    As you can see in the screenshot Snapchat is always at the top of the list of "battery hogs" and it mostly drains at screen off/standby so can anyone offer suggestions in how to fix this or explain why it happens, than you very much.
  2. Android450
    Marshmallow May 20, 2017
    Android450 , May 20, 2017 :
    Snapchat drains everyone knows that. Try clearing data and uninstall and reinstall
  3. kkiiddaa
    Froyo May 20, 2017
  4. Maxmxir
    Gingerbread May 20, 2017
    G_Rajun_Doal_Ieis likes this.
  5. G_Rajun_Doal_Ieis
    alright I'll give it a go, I'll let you know the aftermath
    Android450 likes this.
  6. G_Rajun_Doal_Ieis
    You mean "Force Stop", I have enabled apps auto launch so they shouldn't launch Not sure whether this helps or not?
  7. Maxmxir
    Maxmxir , May 20, 2017 :
    I activate auto launch app and i force stop Snapchat, Snapchat in background kill the battery
  8. G_Rajun_Doal_Ieis
    I know, it's extremely annoying does this happen on all android devices or just OnePlus?
  9. Android450
    All Android Snapchat is just a horrible app like Facebook
  10. G_Rajun_Doal_Ieis
    Facebook is fine for me I used in quite a lot today and it didn't even show up in my battery usage as you can see in the screenshot it's just Snapchat, I think Facebook fixed the battery drain with an update this is exactly what Snapchat needs to do now
  11. Maxmxir
    All device in Android, Facebook, Snapchat, Messenger
    Folio is a good alternative to Facebook but nothing exist for Snapchat
  12. Android450
    I'll have to take a look sometime I haven't used Facebook app in about a month
  13. Matei Person
    Donut May 20, 2017
    Matei Person , May 20, 2017 :
    in developer options you have an option which is called running services, go that and stop snap chat from there. you might close other battery draining apps from there.
  14. G_Rajun_Doal_Ieis
    fair enough, but trust me their is no battery drain for FB at least not for me that is shouldn't drain for you as well
  15. G_Rajun_Doal_Ieis
    isn't that the same thing as "Force Stop"?
  16. Android450
    I'll test it sometime and let you know
  17. Younes Layachi
    Younes Layachi , May 20, 2017 :
    Even if it happened only on OnePlus devices, it's not OnePlus' fault, the Snapchat is just terrible
  18. G_Rajun_Doal_Ieis
    Alright, I'm really hoping Snapchat fixes this "battery drain" with an update just like Facebook did that would be amazing as I use Snapchat on a daily basis.
  19. Matei Person
    Donut May 20, 2017
    it should but, sometimes it starts back with force stop, sometimes not. this method works for me when I don't use the "deep clear" option
  20. G_Rajun_Doal_Ieis
    deep clear? are you on about the multitasking clearing? because I always clear my apps after use
