Snapchat Fix for Failed to Login?
  1. rs98
    Ice Cream Sandwich Dec 18, 2015
    rs98 , Dec 18, 2015 :
    I have a rooted OnePlus 2 and I deleted and reinstalled snapchat because I thought it was glitching, but now it won't let me reinstall it, saying 'your login temporarily failed.' I've googled the topic a bit but have not found a solution? Does anyone know how to fix this? thanks!
  2. rs98
    In case someone needs the help, I did just find out. Basically, Snapchat is checking to see whether you have Xposed framework installed. If you uninstall that and then retry snapchat, it will all work!
  3. dylanpdx
    Cupcake Dec 20, 2015
    dylanpdx , Dec 20, 2015 :
    I heard that once you log-in to Snapchat, you can reinstall Xposed framework again. As long as you're still logged in to Snapchat, it won't complain. But if you log out, you'll have to uninstall Xposed to log back in.
  4. rs98
    Ice Cream Sandwich Dec 21, 2015
