5
Snapchat focus issue
  1. RemiC Froyo Nov 20, 2016
    RemiC, Nov 20, 2016 :
    [OPT]
    Hello,
    When using the rear camera on snapchat, the camera just keeps re-focussing every second or so. Only, it never really get's a good focus, it's just blurry nearly the entire time with a .1 second in actual decent focus.
    While shooting a video on snapchat I have the same issue...
    This problem only occurs when using the rear camera in snapchat, not in any other app.
    Any thoughts on this?
    EDIT:
    yes I am running latest version of snapchat
    yes I have also tried re-installing the app
  2. TomasVait Eclair Nov 21, 2016
  3. RemiC Froyo Nov 21, 2016
    Rahex likes this.
  4. mayankkumar Gingerbread Nov 23, 2016
    F_Jeffrey_Urizar_PZKU and Rahex like this.
  5. RemiC Froyo Nov 23, 2016
    RemiC, Nov 23, 2016 :
    Please all use the report problem function in snapchat so the problem will actually be resolved. Snapchat tends to be pretty slow on these matters...
    Assuming it is a Snapchat problem that is.
    If anyone has a possible fix, please shoot!
  6. saahill Gingerbread Nov 23, 2016
  7. RemiC Froyo Nov 23, 2016
  8. saahill Gingerbread Nov 24, 2016
    saahill, Nov 24, 2016 :
    Yes. OP2. All stock. No Root. OOS 3.1.0
    And its snapchat camera.
    tadydrift likes this.
  9. gudboai Gingerbread Nov 26, 2016
    gudboai, Nov 26, 2016 :
    I used xposed and downloaded the snapchatlensesenabler module and that seemed to help with the problem.
  10. RemiC Froyo Nov 27, 2016
    RemiC, Nov 27, 2016 :
    Does this require a rooted device?
  11. gudboai Gingerbread Nov 28, 2016
    gudboai, Nov 28, 2016 :
    Yes it does. The problem still kind of exists however so it isn't a sure fix
  12. matthu.2711 The Lab - OnePlus 7 Pro Reviewer Nov 28, 2016
  13. gudboai Gingerbread Nov 28, 2016
    I fixed the problem by opting out of snapchat beta and downloading the normal public app.
    TomasVait likes this.
  14. RemiC Froyo Nov 29, 2016
    RemiC, Nov 29, 2016 :
    thank you!
    Issue fixed.
  15. F_Jeffrey_Urizar_PZKU Cupcake Apr 28, 2017
    F_Jeffrey_Urizar_PZKU, Apr 28, 2017 :
    just change the camera to manual! reinstall the app after that and I'll be fine I think. it can't focus with hq or hdr for some reason.
  16. mtstraka Cupcake Dec 1, 2017
    mtstraka, Dec 1, 2017 :
    Still can't get my snapchat front camera to focus. How do you change the camera to manual? Or opt out of the snapchat beta?
  17. G_Joey_Gylytiuk_obhI Cupcake Aug 2, 2019
    G_Joey_Gylytiuk_obhI, Aug 2, 2019 :
    This may have been fixed for some of you, or if you left the beta to fix it. I had the same issue, I have the S10+ and it got a software update then all a sudden Snapchat stopped focusing and the camera was kinda glitchy.
    I found a fix, so far I haven't noticed it happen again but we'll see as the days go on.
    Go into Snapchat and go to settings, down near the bottom, clear your cache and also clear lense data. Seems to do the trick, and I have that beta
    Stineeeeeee likes this.
  18. Stineeeeeee Cupcake Aug 14, 2019 at 12:27 AM
    Stineeeeeee, Aug 14, 2019 at 12:27 AM :
    Just tried this and it worked for me! Fixed it completely woohoo!
