snapchat issue
  1. Chiizis
    Froyo Apr 13, 2017
    Prajaparty likes this.
  2. Laamapalmu
    Jelly Bean Apr 13, 2017
    Laamapalmu , Apr 13, 2017 :
    What OxygenOS version are you running?
    When did this issue first occur?
    Has this happened before?
    Have you re-installed snapchat and/or done a factory reset for your OP3?
  3. Prajaparty
    Cupcake Apr 13, 2017
  4. Chiizis
    Froyo Apr 13, 2017
    Chiizis , Apr 13, 2017 :
    4.1.2
    I don't know. Maybe month before.
    Beginning I don't have rewind. And now doesn't have rewind and fast forward.
  5. pablofg1978
    Spanish POC Assistant Head Moderator Apr 13, 2017
    pablofg1978 , Apr 13, 2017 :
    Moved to support, next time check where you create your thread
  6. Chiizis
    Froyo Apr 13, 2017
    Yes. Nothing changes.
  7. Prajaparty
  8. Laamapalmu
    Try updating to 4.1.3 it was just released. You can use VPN canada for instance to download it immediately. After updating and clearing cache try again and report back if issue is still there.
  9. Chiizis
    Froyo Apr 13, 2017
    V10.6.0.0
  10. Prajaparty
    Prajaparty , Apr 13, 2017 :
    If updating to OOS 4.1.3 like Laama said; doesn't work then try installing the Snapchat Beta and see if it adds the rewind and fast forward option.
  11. bharath898989
    Eclair Apr 13, 2017
  12. AlessandroScevola
  13. Chiizis
    Froyo Apr 13, 2017
    Nothing change.
  14. Chiizis
    Froyo Apr 13, 2017
    It's works. Now I have rewind and fast forward. But beta is buggy. ;(
  15. Prajaparty
    Ahh okay, glad to hear it works, how so is the beta buggy, I've yet to try it on my OP3?
  16. Chiizis
    Froyo Apr 13, 2017
    I didn't understand you. :D
  17. Prajaparty
    My bad, I worded that terribly aha, what is buggy in the beta?
  18. Chiizis
    Froyo Apr 13, 2017
    Lagging.
  19. Prajaparty
    Ahh okay, are you sure it's the beta, was the regular version not lagging, cause Snapchat said it doesn't perform as well on Android devices as compared to iOS devices?
  20. Laamapalmu
    Sometimes when opening a snap it does nothing. It stays on snapchat homescreen and the red square turns to white one with red edges aka. Already watched.
