4
Snapchat update.
  1. jochemjorik
    Froyo Sep 28, 2015
    jochemjorik , Sep 28, 2015 :
    Did you already do the update? It's an huge improvement! And i don't know where you talk about, my phone is working totally fine
    #41
  2. Jupeeeeee
    Jelly Bean Sep 28, 2015
    #42
    simmons.a2 likes this.
  3. simmons.a2
    Cupcake Sep 28, 2015
    simmons.a2 , Sep 28, 2015 :
    Haven't got the update yet.
    #43
  4. nnewgenn
    Donut Sep 29, 2015
    nnewgenn , Sep 29, 2015 :
    I just updated my Oxygen, enrolled in the snapchat beta and updated snapchat but still doesn't work. Just to be sure, you put it on selfie mode then tap and hold on where your face is right??...doesn't work for me :(
    #44
  5. fanador
    Eclair Sep 30, 2015
    #45
  6. aleb91
    Gingerbread Oct 4, 2015
    aleb91 , Oct 4, 2015 :
    Doesn't work for me either with the OPO and latest snapchat version
    #46
  7. nutzy73
    Froyo Oct 4, 2015
    nutzy73 , Oct 4, 2015 :
    Snapchat animations worked on the Oxygen 2.0.3 for me when I got the OPT.
    • I rooted and installed 2.1 and no more animations.
    • Changed to AK Kernel, no animations.
    • Clean stock installed 2.1 still no animations.
    • Face detection works well with the camera app.
    Don't know if it has something to do with Oxygen 2.1 or whatever.
    PS: I've always been a Snapchat beta tester, so every version I used was beta, I don't know anything about the behavior of the stable version on the OPT.
    PPS: When using onscreen buttons, Snapchat doesn't detect them so Snapchat buttons are under the layout of the Lollipop ones, which makes them difficult/impossible to reach. Basically, when I try to hit the Send button, I hit the Back button of Android. I don't know it this happens with other apps or it's just a Snapchat bug.
    #47
  8. Vico479
    Cupcake Oct 8, 2015
    Vico479 , Oct 8, 2015 :
    The snapchat face recognition doesn't work but there is alos another problem that I am facing regarding recording videos. I've searched online for the solution but it turns out that even if the device itself is mute, whenever you hold the button to record, the sound will always play.
    #48
  9. oreva12
    Cupcake Oct 24, 2015
    oreva12 , Oct 24, 2015 :
    I am having the same issue with chats and the Snapchat animations.
    #49
