5
Snapdragon 810 heat issue
  1. zhaogeorge3
    Jelly Bean Aug 12, 2015
    zhaogeorge3 , Aug 12, 2015 :
    Just got my ZTE Axon it has the snapdragon v2.1 and the heat issue is not fixed despite what Qualcomm says or One Plus. It gets hot watching YouTube videos and browsing the web for 2 minutes.
    The heat from browsing the web is equivelent to gaming for an hour on the one plus one
    And it eats up battery life.
    I think I'm gonna return it and get the moto X style
  2. DaxNagtegaal
    Marshmallow Aug 12, 2015
  3. nanoball_007
    Gingerbread Aug 12, 2015
    Jorge48197 likes this.
  4. nunopinho1982
    Lollipop Aug 12, 2015
  5. jimmyst
    Ice Cream Sandwich Aug 12, 2015
    jimmyst , Aug 12, 2015 :
    Thanks for sharing
  6. Chugz
    Chugz , Aug 12, 2015 :
    Won't help a lot, copper plating helps more.
  7. Renegron
    Christian_yn likes this.
  8. magnamentis
    magnamentis , Aug 12, 2015 :
    your logic is biased, because you chose a cheap unknown brand you assume it's the same for all others. the 2 does not overheat like so many others which were said to. you fell for the wrong specs. i know it because i checked on that phone and discarded it for good and now for even better reason
  9. RR10001
    Honeycomb Aug 12, 2015
  10. Methiri
    Methiri , Aug 12, 2015 :
    What's the ZTE Axon got to do with the OP2? It's about more than just the processor used.
  11. zhaogeorge3
    ZTE is the 4th largest smartphone maker......... and its the exact same CPU which means heat output is going to be the same
  12. zhaogeorge3
    The processor is the source of the heat issue
  13. sid_369
    sid_369 , Aug 12, 2015 :
    cheap unknown???? ZTE has been around for a long time!
    MagicMagicD and zhaogeorge3 like this.
  14. Smartglomeux
    Cupcake Aug 12, 2015
  15. Kinky
  16. mysticus
    mysticus , Aug 12, 2015 :
    biased maybe, but you/me/we/who dont know anything yet... before anyone keep coming with stupid comments like x product overheats so dont buy it, or Y product is better etc... X product is bad is bad, we dont know Y products is same or not yet, so lets all not make assumptions and start whose penis is bigger fights for something we dont know yet... it could be dud, it could be better... just wait until u got the thing... if you dont wanna be guinea pig, so dont be, just wait and see others take the hit!
  17. Methiri
    Yes but it's about how that is housed and dissipated. Copper or graphite plating, thermal gel, materials on back....what does the ZTE Axon use?
  18. Gurkha
    Gurkha , Aug 12, 2015 :
    Its the clock speed that overheats it and the all metal frame and case.
    Axon running At 2.1ghz while OP2 at 1.8.
    Also GPU running slower too and no NFC or fast charge enabled in the 2. All extra processes that cause heat.
    OP2 won't overheat.
  19. zhaogeorge3
    Axon is running at 2.0 ghz and where did one plus say they were underclocking the OP2.
  20. sidlittlefield
    KitKat Aug 12, 2015
    sidlittlefield , Aug 12, 2015 :
    Did you ever get anyone to help you out? I will definitely help assuming OnePlus remembers to ship their phones to the US this time.
    DaxNagtegaal likes this.
