14
So basically 4.0.2 not exactly a success? or is it?
  1. F_Sparsh_Bhatia_yUrJ
    Gingerbread Jan 30, 2017
    F_Sparsh_Bhatia_yUrJ , Jan 30, 2017 :
    There is something about rooting that gets me... I don't want to root.. But i also want to root... I just don't have much knowledge about rooting..
    #41
    nikitaindik and Alexander111 like this.
  2. Sun90
    Starting Point Expert Community Expert Jan 30, 2017
    Sun90 , Jan 30, 2017 :
    Nothing epic, to be honest.
    Just use the phone the way u want with as minimal bloat ware as possible.
    That's it.
    And always be on stock recovery.
    #42
    pa5t1s likes this.
  3. Sun90
    Better to stay away, unless u need to run some apps inevitably that seek it.
    #43
  4. pa5t1s
    User of the Year 2014 Jan 30, 2017
    pa5t1s , Jan 30, 2017 :
    Do a "Search" and you'll find your answer...
    #44
    Sun90 likes this.
  5. F_Sparsh_Bhatia_yUrJ
    Well ya.. That's why I never liked the idea of rooting.. If I go the rooting way.. What's the purpose of buying a phone that has 3gigs doing nothing and an oxygen OS with every update tries to bring in new optimization.. But that could be true to other phones too..!
    #45
    Sun90 likes this.
  6. F_Sparsh_Bhatia_yUrJ
    #46
  7. Sun90
    May be,
    But lot of them seek root mainly to run apps that seek root privileges,like viper4android Android, Root explorer etc.
    Or to run xposed modules.
    #47
    F_Sparsh_Bhatia_yUrJ likes this.
  8. hancy_2050
    Cupcake Jan 30, 2017
    hancy_2050 , Jan 30, 2017 :
    after update battery drains drastically.... pls look into battery issue soon... op3
    #48
  9. F_Sparsh_Bhatia_yUrJ
    Ya.. I know.. The root privileges as they say...!! Maybe I am just fine with the stock experience.. But a few fixes from Oneplus won't be bad
    #49
  10. Gauravkadam
    Gauravkadam , Jan 30, 2017 :
    Hi, after doing the recent system update on my op3, my back camera is not able to auto focus and the photos are coming blur. Please advice.
    #50
  11. F_Sparsh_Bhatia_yUrJ
    Are you sure that you are not on manual mode with extremely less ISO with focus in the other direction and shutter speed too high?
    #51
  12. Pablo_C
    Eclair Jan 30, 2017
    Pablo_C , Jan 30, 2017 :
    I hate the volume restrictions, it's so annoying not to be able to mute the device when receiving a call or when disconnect my headphones while I'm in a video call. I'm so frustrated with that new actualization because of that
    #52
    rukkus likes this.
  13. vintagetech
    Honeycomb Jan 30, 2017
    vintagetech , Jan 30, 2017 :
    That depends... I don't use WiFi at work and generally in can get away with not using my phone at work. I can usually keep my phone to about 60% to 70% battery by 3pm to 4pm if I keep the screen off most of the day. I plug my phone in when I drive to work - so it gets topped off after i have charged it over night. It usually gets taken off the home charger around 630am to 7am. When I am at home I am on WiFi. So sot for a work day could be up to 6+ hours if the phone stays off and depending on how many times I plug it in when I'm driving somewhere. At home I usually have to charge it two to three times.
    #53
  14. F_Sparsh_Bhatia_yUrJ
    Yeah.. Two to three charges here as well.. When am out.. I switch to the battery saver mode... And have my data saver on... That usually lasts me a day and half.. With a good amount of SOT.
    #54
  15. ghostofcain
    Marshmallow Jan 30, 2017
    ghostofcain , Jan 30, 2017 :
    These are probably down to apps not yet optimised to nougat, have you seen the number of 1 star reviews Amazon has had recently.
    Not on Nougat they don't.
    I unplug about 7 am, use it a fair amount during the day mostly on WiFi and plug it in sometimes as early as 9pm, often around 12 getting around 5 hours SoT which for me is comparable with past phones.
    There's a poll on these threads where 60‰ of users say they have no issue with 4.0.2, as forums are somewhere people come to complain I think that says enough for me. BTW most users without problems have clean flashed the ROM or carried out a factory reset after installation maybe that tells you something.
    #55
    F_Sparsh_Bhatia_yUrJ and Sun90 like this.
  16. hugoaferreira
    hugoaferreira , Jan 30, 2017 :
    here overall is really good but they need to work on the battery life. 4/5 hours of sot is not that much. on version 4.0 I consistently had 5/6 sot.
    #56
  17. F_Sparsh_Bhatia_yUrJ
    +1 on that.
    #57
  18. Proff_milan
    Donut Jan 30, 2017
    #58
  19. F_Edina_Pap_ycRr
    Donut Jan 30, 2017
    F_Edina_Pap_ycRr , Jan 30, 2017 :
    is there a 3t section??
    #59
  20. Alpha Mike Foxtrot
    KitKat Jan 30, 2017
    #60
