Display Software issue or faulty screen replacement?
  1. DrDarthZ
    Cupcake Aug 23, 2019
    DrDarthZ , Aug 23, 2019 :
    So I broke my screen kept it lying around for 2months then finally got it fixed this week from a 3rd party service
    After replacement my power button doesn't wake up the screen at once
    prolly press 20 times before it wakes up
    The capacitive buttons light up on each press and even vibrates with fingerprint but screen stays off
    It works fine in twrp lock screen. Locks and wakes up properly there.
    The repair guy said that it's a software problem so he'll software reset it for for me I send it back
    just clean flash havoc os latest but still the same problem
  2. Paschfire
    KitKat Sep 7, 2019
    Paschfire , Sep 7, 2019 :
    Then it's not a SW issue, you more than likely need to have the power button replaced.
