36
Soldering in an inductive charging coil internally.
  1. inaudible101
    Gingerbread Jul 15, 2014
    inaudible101 , Jul 15, 2014 :
    Hey guys,
    I've been using my one with a USB inductive charging adapter. I'm coming from an S4 that has the contact points under the back cover for an inductive charger and I'm a little annoyed with not being able to use my USB port with this adapter. I was looking at the tear down of the on on ifixit and noticed that the USB solder points are easy to get to and are just covered by a piece of screwed down plastic. I'm thinking of soldering in a could under the back cover so that I may use my USB port without having to take my case off and unplugging the adapter. If there is enough interest here for this I can give it a shot and post a tutorial.
    If anyone has experience with these types of mods I would be interested in hearing if you think it would effect the USB port for normal charging or usage. Since the USB port does not require grounded data pins for charging I can't see why it would cause any issues.
    Thanks for looking!
    [UPDATE]
    Since all the comments below were super unhelpful, I got impatient and cut up my usb receiver I had been using. It works ok, but the back case seems to add either too much thickness or the antennae in the back that goes right over the receiver causes enough interference for it to be finicky. Once replacement backs are available I will probably cut a slot in one so the receiver is on the outside with the wires running inside.
    I purchased the receiver I used on ebay here http://www.ebay.com/itm/310947772910?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 It says it's 750mA but when I took the rebranded sticker off it says 1000mA for the output. I plan on trying out the new ones I have on the way. Here's a gallary of the modification.
    http://imgur.com/a/jRnN4
    If anyone else is going to attempt this and has any questions let me know.
    UPDATE 8/19
    Here is an album showing how I currently have everything working internally.
    http://imgur.com/a/63Aj7
  2. Reflect Stratos
    KitKat Jul 15, 2014
  3. gatenosix
    KitKat Jul 15, 2014
    denvit and Reflect Stratos like this.
  4. coletuck
    Honeycomb Jul 15, 2014
    jessicab likes this.
  5. justyfier
    musictombo, itsMickle and farangutan like this.
  6. inaudible101
  7. tntpop
    tntpop , Jul 15, 2014 :
    Someone posted on the forums about this.
    Look it up, it's already done...
  8. inaudible101
    Nice thanks. I have been keeping my eyes out for this since about a month ago and must have missed it. Sorry for the repost.
    ShyvHD and tntpop like this.
  9. tntpop
    That's Ok ... I just can't remember the name of the poster
  10. inaudible101
    Yeah, I'm searching but I'm not finding anything besides dumb speculation. I think I'll order the part and post a how to about it unless I find this other thread.
    Bradleyw801 and CtapukaH like this.
  11. Drees
    Eclair Jul 15, 2014
    Drees , Jul 15, 2014 :
    I'm interested in the tutorial. If you do, please post it. The more, the better, right?! ;)
    tekrytor likes this.
  12. tntpop
    The search really sucks
    There's a guy who don't and posted the tuto on the forum...
  13. tntpop
  14. kstaplet
    Ice Cream Sandwich Jul 15, 2014
  15. tntpop
  16. KratosPS
    KitKat Jul 15, 2014
  17. tntpop
  18. inaudible101
    Those are just usb adapters which I am currently using. I just ordered two 1000mA adapters that I will use. I ordered two in case I fubar one. The most experience I have with soldering on this level is when I installed two internal thumb drives on my dell venue 8 and these soldering points look much larger. I'll go ahead and update the post with pictures and progress once I receive the items. If I get impatient I may cut up the usb receiver I am using currently.
  19. tntpop
    The last link I posted
  20. inaudible101
    Yeah he just put the coil in a case and used the usb plug. He didn't open up and solder anything. I want to be able to have the usb port open while having the adapter internal. He is doing exactly what I'm doing currently.
    Mychal likes this.
