48
Solution: Bricked OnePlus One Recovery.
Vote If this method helped.
  1. Yes
    58 vote(s)
    76.3%
  2. No
    22 vote(s)
    28.9%
Multiple votes are allowed.
  1. KforHorizon
    KitKat May 18, 2015
    KforHorizon , May 18, 2015 :
    thanks for the concern mate! but i dont have my one now.. its in a service center for almost a month! :p touch issues! :confused:
    #61
  2. pmdsp
    Honeycomb May 18, 2015
    pmdsp , May 18, 2015 :
    :eek:
    #62
  3. fbaetz
    Cupcake May 18, 2015
    fbaetz , May 18, 2015 :
    Already did: different computers, different cables, different chargers... but nothing helps unfortunately. I fear that one is dead for good. Still waiting for OnePlus support team to follow up on my ticket. Hopefully I can get it exchanged quickly for one which is working...
    #63
  4. bunderson
    Donut May 20, 2015
    #64
  5. ferozgandhi007
    Honeycomb May 20, 2015
    ferozgandhi007 , May 20, 2015 :
    Thanks Bro
    #65
  6. alberto_gms
    Donut May 21, 2015
    #66
  7. pmdsp
    Honeycomb May 22, 2015
    pmdsp , May 22, 2015 :
    Not sure why you are referring to this thread. Your phone is working fine just use my rollback thread in my signature to install the CM11s.
    #67
  8. buijk51
    Gingerbread May 25, 2015
    buijk51 , May 25, 2015 :
    I'm not sure if this has been asked before but can a similar process be used to restore, for example an HTC?
    #68
  9. submerged
    Cupcake May 27, 2015
    submerged , May 27, 2015 :
    Thanks for giving this guide. It was totally dead, no LED, vibration.. nothing. And now it's up and running again. I followed the youtube video here on page 2. Awesome!
    #69
  10. PeteT
    Froyo Jun 1, 2015
    PeteT , Jun 1, 2015 :
    Thank you for the guide. I too had this problem and i thought my phone was totally one. I have just followed the instruction/youtube video from page 2 and my phone is alive again. BTW i did this from windows 10 preview too.
    #70
  11. Donglejitter
    Cupcake Jun 12, 2015
    Donglejitter , Jun 12, 2015 :
    Just wanted to pass my thanks onto you for saving my OPO with this guide. I followed the guide using an old XP machine and it worked perfectly. I'd previously spent 14+ hours trying to get Windows 7 to recognise the device and install the drivers but I didnt have the skill to manually load the drivers. XP worked a treat for me.
    #71
  12. silvagroup
    Honeycomb Jun 13, 2015
    silvagroup , Jun 13, 2015 :
    Not sure about Kindle Fire HDX but for my Kindle Fire HD had to have a fastboot usb cable.
    #72
  13. DeadlyMelqn
    Donut Jun 13, 2015
    #73
  14. Aurodeus
    Froyo Jun 14, 2015
    Aurodeus , Jun 14, 2015 :
    Seems like a clear and easy to follow guide, I'm a newb, never root, never flash. I wonder if I need to do this. My phone is not bricked, but it can't detect SIM Card and cannot connect to wifi although it detects them, and IMEI is gone :(
    Sorry, need 5 replies to create a new thread.
    #74
  15. pmdsp
    Honeycomb Jun 15, 2015
    pmdsp , Jun 15, 2015 :
    Try following this method or use the one plus customer care.
    #75
  16. rubenium
    Froyo Jun 19, 2015
    rubenium , Jun 19, 2015 :
    Same problem here with the sahara issue trying to unbrick using the download tool. Did you find the solution to this?
    #76
  17. squiddy_2000
    Froyo Jun 27, 2015
    squiddy_2000 , Jun 27, 2015 :
    I have followed everything in this guide, the tool shows that all the drivers have been installed on the phone fine. But i am not able to reboot my phone in to fastboot. it simply refuses to turn on. Can anybody help?
    #77
  18. slsl20005
    Cupcake Jul 3, 2015
    #78
  19. ptran
    Eclair Jul 3, 2015
    #79
  20. alan2500
    Cupcake Jul 4, 2015
    alan2500 , Jul 4, 2015 :
    When i try to select the folder (mine is just called Qualcomm 2012, not the same as the one in the picture of the guide) with the driver in step 2, it says this: Windows has found driversoftware for the unit but there was an error when trying to install it. The hash for the file is not in the given catalogue file. The file is most likely damaged or has been changed. What should i do now? Also, when i plug my phone in, my pc sees that there is something being connected, but it does not know what it is, if that makes a difference. Here is my reddit post on the matter https://www.reddit.com/r/oneplus/comments/3bzwel/my_one_is_not_booting_at_all_and_does_not_react/
    #80
    pockyrox likes this.
