43
[Solution] : Low Battery Or Full Black Screen & OPO Not Booting Due Over-discharge
  1. sukanta.hazra
    Ice Cream Sandwich Aug 15, 2014
    sukanta.hazra , Aug 15, 2014 :
    Hi Friends,
    I faced the the same issue and it is solved now....
    See the link below and follow the trick (if required repeat the trick for 2 or 3 times)
    https://forums.oneplus.net/threads/oneplus-one-not-charging-fixed-added-video.77439/
    Thanks to @jayb222
    In My Case, I did the following steps...
    After getting a full black screen (even no "low battery warning" screen after 1 day) and not even boot into recovery / fastboot...
    1) Kept the phone for 12 hours without touching and charging...
    2) Plug official charger and usb for a moment... and tried booting... Nothing happend
    3) Charged with official charger and usb for 6 hours and then
    4) Pull off the usb and put back again ... and i got the LOW battery screen again,
    WOW, staying for 4 / 5 mins...
    5) Now don't try to boot or anything.. keep it charging for 30 mins more and let it be charged
    upto atleast 10% (you will see normal charging battery icon screen) even
    it is black.
    6) Now finally boot your device by pressing power button for few seconds
    7) Phone should boot normally...
    Note: NEVER Let your Lipo / Li-ion battery discharge below 3% to avoid this kind of problem... otherwise Battery protection circuit will be activated and hence preventing your device to accept charge...
    Best charging practice for lipo battery is Partial Charge, like -- 30% to 80% or 10% to 90%
    Let us know the result....
    Another Solution , if the above process not worked ...
    2) Submit Ticket to OnePlus Support or ask for RMA.
    3) Disconnecting and re-connecting the battery Like --
    https://forums.oneplus.net/threads/oneplus-one-battery-dead-issue-solved.41777/
    4) =================== THEORY ====================================
    for Lipo Li-ion batteries.... if it discharges lower than a battery voltage (say less tha 3volt / 2.7 volt)
    If the lipo battery voltage drops below 1.5Volt, it might damage forever. Boosting it will not help to bring it's life back.
    then a security protection battery circuit takes into action and prevents the battry to get charge ... and goes into a deep sleep mode
    if someone can charge that battery with some special charger (NiMH) with 1C, 1amp charger for 15 sec to 1 min , it will then deactivate the protection and after that , we can normally charge that battery
    here is the link for it --- http://www.rcgroups.com/forums/showthread.php?t=1072324
    http://batteryuniversity.com/learn/article/low_voltage_cut_off
    :cool::D:p:);):rolleyes::eek:
    webdel52, taka61, eLedar and 40 others like this.
  2. drmartin
    Moderator Moderator Aug 15, 2014
    drmartin , Aug 15, 2014 :
    Thanks for sharing your experience, never heard of this problem before!
    hot_as_fire and McAwesomePL like this.
  3. Nilesh Sajnani
    KitKat Aug 15, 2014
    eragon86 likes this.
  4. malidan
    Nougat Aug 15, 2014
  5. Max741
    Eclair Aug 15, 2014
  6. sukanta.hazra
    dasari murthy likes this.
  7. Blachloq
    Gingerbread Aug 15, 2014
    Max741 likes this.
  8. Blachloq
    Gingerbread Aug 16, 2014
    Blachloq , Aug 16, 2014 :
    ...OMG .. It works .. thanks for the hint to wake the sleeping beauty again...:D:D
    ReRunRod and ronclon like this.
  9. luckyfmj
    Ice Cream Sandwich Aug 16, 2014
    luckyfmj , Aug 16, 2014 :
    i always charge my opo when it is near 3 %. never seen something like that.
  10. rafaelraposo
    Froyo Aug 16, 2014
    rafaelraposo , Aug 16, 2014 :
    Thank you for letting us. Today my OPO discharged completely, just had to plug it in and charged perfectly but I'll try to avoid those kind of situations.
  11. johnnytensai
    johnnytensai , Aug 16, 2014 :
    @sukanta.hazra
    thanks for your update,
    however, i think my problem is a bit different from yours, please hear me out and please help me out.
    here is my problem:
    • the screen is black but the backlight comes on but no type of screen images come up.
    • i can still lock and unlock my phone, i can hear the sound also.
    • ive tried restarting my phone, with the volume down and power, but nothing comes up.
    • occasionally, the screen is displaying something, but the display is disrupted, just like a jigsaw puzzle.. after that, it is not responding.
    • Is it a LCD problem?
    thankyou, my friend..
    at the same time, i will be trying your method too.
  12. sukanta.hazra
    sukanta.hazra , Aug 16, 2014 :
    I guess , it is not battery problem... Can you see boot logo, when you pressed power button ?
    Try to boot into fastboot (vol up + power .. when vibrates , release all) , then freshly install cm11s
    Follow this link ...
    http://forum.xda-developers.com/oneplus-one/general/guide-return-opo-to-100-stock-t2826541
    -fastboot flash boot boot.img
    -fastboot flash system system.img
    -fastboot flash recovery recovery.img
    -fastboot flash cache cache.img
    -fastboot flash modem NON-HLOS.bin
    -fastboot flash sbl1 sbl1.mbn
    -fastboot flash dbi sdi.mbn
    -fastboot flash aboot emmc_appsboot.mbn
    -fastboot flash rpm rpm.mbn
    -fastboot flash tz tz.mbn
    -fastboot flash LOGO logo.bin
    -fastboot flash userdata userdata_64G.img
    -fastboot reboot
    it problem persists ... most probably LCD H/W prob... go for RMA / Support ticket...
    IWantOneNow likes this.
  13. johnnytensai
    i cannot see the boot logo><
    i m going to go for your second recommendation
  14. Max741
    Eclair Aug 16, 2014
    Max741 , Aug 16, 2014 :
    I'd Just like to tell the OP that I love him in the strictest non-homo way :')) Cause now my baby is alive and running again.... Hope was still alive and I'm so happy!! They should make this a sticky just in case other people have the same problems they can find the solution easily.
  15. sukanta.hazra
    Ice Cream Sandwich Aug 17, 2014
    sukanta.hazra , Aug 17, 2014 :
    I am glad that, it worked for you .... I need a little "like" from you... :p
    *kidding"
    paulo111 likes this.
  16. Max741
    Eclair Aug 17, 2014
    Max741 , Aug 17, 2014 :
    You got my love \o/!!
    sukanta.hazra likes this.
  17. sukanta.hazra
    Chaut59 likes this.
  18. auliasinadya
    Gingerbread Aug 17, 2014
  19. flolaff
    Eclair Aug 17, 2014
    flolaff , Aug 17, 2014 :
    Agreed. It gave life back to my One !
    J50, Max741 and sukanta.hazra like this.
  20. sukanta.hazra
