[Solution] Missing Face Unlock Fix
  1. TekRantGaming
    Ice Cream Sandwich May 7, 2015
    TekRantGaming , May 7, 2015 :
    sometimes the gapps package you flash will not include face unlock and you don't want to flash the gapps package that has face unlock in it because it comes with too many google apps you don't want. so here is the standalone face unlock zip just flash it in recovery and reboot you will now have face unlock as an option on smart lock.
    For cm12 or the now new cm12.1 (any lollipop rom realy)
    I got it here http://forum.xda-developers.com/google-nexus-5/themes-apps/gapps-smart-unlock-android-5-0-t2962765
    some people are having problems finding the download button on the above link so here is a direct link get 5.0.2 if your on that and 5.1 if you on that one
    https://www.androidfilehost.com/?w=files&flid=23253
    pbergonzi likes this.
  2. enepe
    Cupcake Jul 7, 2015
    enepe , Jul 7, 2015 :
    Hello
    I've been avoiding the update as I don't want to lose the face unlock.
    Does the phone need to be rooted to do that?
    I currently am on original 4.4 with unlock bootloader but not rooted phone.
    Thanks
  3. EpicSwirly
    Jul 7, 2015
    EpicSwirly , Jul 7, 2015 :
    The thread is talking about custom ROM's and gapps packages if you're updating from CM11s to COS 12 then it will be there. This is talking about how different gapps come with different packages. It does not concern the stock ROM(CM11s and COS12) as it those already have gapps and if you're just updating it shouldn't be a concern,
  4. enepe
    Cupcake Jul 7, 2015
    Thanks, however I'm not so sure about that
    Some friends have the stock update (OTA), no rooted phones, and they don't have the face unlock
  5. sp99
    Community Veteran Jul 7, 2015
    sp99 , Jul 7, 2015 :
    After the official COS update it will be under security->smart lock :)
    Deactivated User likes this.
  6. enepe
    Cupcake Jul 7, 2015
    Many thanks...
    I need to exchange my friends for others that now how to use their OPOs ;)
    sp99 likes this.
  7. TekRantGaming
    Ice Cream Sandwich Jul 7, 2015
    TekRantGaming , Jul 7, 2015 :
    Update its fixed now your cool
  8. grovewar
    Cupcake Aug 21, 2015
  9. asj0422
    Honeycomb Oct 3, 2015
    asj0422 , Oct 3, 2015 :
    This crashes after I flash the file and try to use it... I'm sure I downloaded the right one, any ideas? It crashes after I try to set up the face unlock
  10. TekRantGaming
    Ice Cream Sandwich Oct 3, 2015
    TekRantGaming , Oct 3, 2015 :
    what ROM are you using ?
  11. asj0422
    Thanks for the response... I figured it out though. I had to get a different zip with updated binaries lol
  12. asj0422
  13. TlathamXmahtalT
    KitKat Oct 3, 2015
    TlathamXmahtalT , Oct 3, 2015 :
    Link to the zip? Maybe @TekRantGaming can update the OP.
  14. asj0422
  15. TlathamXmahtalT
    KitKat Oct 3, 2015
    Does it work on most 5.1.1 ROMs?
  16. asj0422
    Honeycomb Oct 5, 2015
  17. asj0422
  18. TekRantGaming
    Ice Cream Sandwich Oct 5, 2015
    TekRantGaming , Oct 5, 2015 :
    i checked when i saw people on this the link is up to date (updated it but its still same link just this time a direct download link)
  19. dhaval.soneji
    Donut Apr 14, 2016
  20. TekRantGaming
    Ice Cream Sandwich Apr 15, 2016
    TekRantGaming , Apr 15, 2016 :
    i should do yea
    dhaval.soneji likes this.
