9
[Solution] White navigation bar
Is this solution useful
  1. Yes
    33.3%
  2. No
    66.7%
  1. BrainsCollector
    Honeycomb Dec 10, 2017
  2. G_Mr_....
    Jelly Bean Dec 10, 2017
    G_Mr_.... , Dec 10, 2017 :
    Hi it goes to show people complain all the time & when someone takes time to find a solution they ignore it.
    Good look, good find.
  3. taar1
    Donut Jan 17, 2018
    taar1 , Jan 17, 2018 :
    Thanks! That's exactly what I was looking for. I hope the Oreo update will fix the issue, though.
  4. warblad13
    Gingerbread Jan 17, 2018
    warblad13 , Jan 17, 2018 :
    doesn't work while in screensaver mode. that's the main reason, don't want burn in
  5. BrainsCollector
    Honeycomb Jan 17, 2018
    BrainsCollector , Jan 17, 2018 :
    You are welcome. I hope that they will add gesture based navigation like in iPhone X, there were rumors about it in few threads, that would be ultimate burn in prevention and full screen use trick
  6. HamzaKovsky Elk
  7. Deactivated User
    Jan 17, 2018
    Rizla likes this.
  8. BrainsCollector
    I was trying to use it but it's not well implemented, for example it is blocking Google chrome bottom navigation bar. What I think it should be alike, that OnePlus should make navigation bar transparent and add some icon, it might be line like in that app, so it's basically the same thing like it is now but with completely transparent background with one button on the middle that is swipable left and right for back and recent and press for home screen, so there is still some margin that would block applications from interfering with navigation button.
    Deactivated User likes this.
  9. Ahridok
  10. Rizla
    Jelly Bean Jan 17, 2018
    Rizla , Jan 17, 2018 :
    I couldn't live without X Home Bar now. It's fantastic :)
  11. Ahridok
    Ahridok , Jan 17, 2018 :
    Never mind it needed permission, any idea how it might effect on the battery life?
  12. BrainsCollector
    It needs some perpermission to monitor behavior on phone but it's only to detect launched apps, I don't feel that it use battery, even if any it's not more than 1% per charge, I never seen this app on battery statistics
  13. Lucky M. Nelson
    Froyo Jan 17, 2018
