[Solved][Closed]Red cable club via OnePlus Nord
Thread Status:
Not open for further replies.
  1. Raghavb149
    Cupcake Sep 23, 2020
  2. camohan
    Marshmallow Moderator Sep 23, 2020
    camohan , Sep 23, 2020 :
    Hi there, can you share some screenshot which can help understand more.
  3. Raghavb149
    Raghavb149 , via OnePlus Nord , Sep 23, 2020 :
    Only this appears. And nothing else. Earlier I was able to see my rewards that I collected and some other benefits also. But now I am not able to do so. I am tired of making complaint and asking what is update. This kind of things I have never experienced.
  4. camohan
    Ok understood. Are you on latest OOS version?
  5. Raghavb149
  6. camohan
    Ok.
    1. Can you also check if the community app is also updated. If yes, please go to profile section, click on red cable club and see if things are displayed properly. ,
    2. You can also see by going to Settings and tap of red cable club banner.
    3. Another option is to check here - https://www.oneplus.in/membership-center?from=head
    Let me know what is the outcome you get
    Cheers.
  7. Raghavb149
    thanks a lot for the help. it's working but apps were already updated. all I did is that I logged out and then logged in.
  8. camohan
    Thats great. Sign out anf logging back magically solves so many issues. Glad things are ok now. Will mark this as solved and close the thread.
    Cheers.
