Sound [SOLVED] Default in-call volume at 100%
  1. FlorinZ6
    Cupcake Mar 29, 2018
    FlorinZ6 , Mar 29, 2018 :
    Hello,
    Whenever I place / receive a new call the in-call volume is set at 100%.
    Even if I change it to 40-50% during the ongoing call, after I finish and a new call is initiated / received it is again set to 100%.
    It is resetting automatically to 100% and does not keep the 40-50% setting that I prefer.
    I am not making WhatsApp or Messenger calls, just voice calls.
    I could not find the "in-call volume" setting in "Sound & vibration".
    Any help is welcomed, thank you.
    Screenshot_20180329-090232.jpg Screenshot_20180329-093753.jpg Screenshot_20180329-090232.jpg Screenshot_20180329-093753.jpg Screenshot_20180329-084335.jpg
  2. dsmonteiro
    Community Consultant Community Expert Mar 29, 2018
    dsmonteiro , Mar 29, 2018 :
    Just typical troubleshooting: Did you try to clear the cache? Sometimes it fixes some of these small bugs that only some people are facing.
    Follow the steps to clear cache of Oneplus 3 without wiping data:
    1. First of all turn off your phone. and get into recovery menu.
    2. Now, to get into recovery menu. Press Volume Down + Power Button. And keep on holding the buttons till you get into recovery menu.
    3. Select Language.
    4. Use volume buttons to navigate to Clear Cache/Data. and use power button to select this option.
    5. Now you will see two separate options, One will clear cache of your OnePlus 3 other one will delete all the data present in your phone.
    6. Select Wipe Cache Option.
    7. Reboot your phone.
    Also, I'm moving your thread to OnePlus 5T General Support.
    FlorinZ6 likes this.
  3. FlorinZ6
    Hello dsmonteiro,
    Thank you for your quick reply. I did the wipe of the cache but that did not helped.
    I managed to solve the problem: it was a setting of a recording call app.
    If anyone else is having this problem please disable the "Increase recording volume" setting.
    Please see the pictures below:
    Thank you for everything! I am enjoying the 5T everyday.
    Best regards, Florin!
    (this thread can be marked as SOLVED)
    keithnyc and dsmonteiro like this.
