[Solved] Less Screen Resolution Y series 43 inch via OnePlus 6
  1. DavidMeshach
    Eclair Feb 27, 2021
    DavidMeshach , via OnePlus 6 , Feb 27, 2021 :
    Hello Guys,
    I'm using Oneplus Y series 43 inch, As per spec Y series 43 inch TV display resolution is 1920x1080 FHD but TV internal spec and YouTube viewport shows that 1280x720p only. Why it showing like that. Can anyone explain it . Herewith attached snapshots for your reference
    With regards,
    A.David Meshach
  2. Venky61
    OnePlus TV Expert Community Expert Feb 27, 2021
    Best Answer
    Venky61 , Feb 27, 2021 :
    Hi,
    There's no issue with the TV, don't worry.
    Android TV app interfaces are always designed for a lower resolution than the display's resolution. This is only for app's interfaces and not the video playback as clearly even your video shows playing at 1080p.
    The same happenz with 4k tvs, it shows 1080p as display resolution in TV info apps and view port on youtube. Hope this clears your doubt.
    Thanks for the tag 😊
  3. .Deleted_Member.
    Nougat Feb 27, 2021
  4. DavidMeshach
    Eclair Feb 27, 2021
  5. DavidMeshach
    Eclair Feb 27, 2021
  6. DavidMeshach
    Eclair Feb 27, 2021
  7. Tobikage
    Nougat Feb 27, 2021
  8. DavidMeshach
    Eclair Feb 27, 2021
    Thanks for clarifying...
    Yash Pratap Singh. and Venky61 like this.
