Sound [solved] Low bluetooth audio on headphones 5T
  1. nickhell
    Gingerbread Jan 10, 2018
    nickhell , Jan 10, 2018 :
    Hi, I just received my bluetooth Creative Outlier Sports and I have a very low audio on my 5T. At max it seems its at 50% and If I lower the audio to 50% I can barely hear anything. Like It would be set at 5 -10 %. I have selected APTx as codec as my headset is supposed to handle it.
    Also using the provided EQ makes not much different in audio tweaking, nor with profiles nor with manual settings.
    The BT audio is ok when connecting to my cars audio system though.
    Anyone has the same problem?
    I´m about to report it as a bug.
    PD. I have also the little distortion in speaker and BT, chopping from time to time but thats another issue and it´s a known bug.
  2. nickhell
    Well, my bad. Apparently it´s not a bug. I have disabled the "Disable absolute volume" in developer options and now the volume works as expected.
    AlexFrancisco91 likes this.
